Thread: Harmonic balancer question
Results 1 to 4 of 4
  1. #1 Harmonic balancer question
    SE Level Member gbgn1's Avatar
    Dec 2012
    TX
    Ive got a l67 in my project car and right now it has a fbody flywheel installed. Would it be ok if i installed the fbody balancer? Would that equal it out? Im assuming you cant run a s/c balancer with the na flywheel.
    Thanks!!
  2. #2 Re: Harmonic balancer question
    I don't think it matters at all.
    Just run whatever balancer you need to run, if you are staying supercharged, keep the L67 HB. 2 belt setup is better IMO.
  3. #3 Re: Harmonic balancer question
    Dec 2012
    TX
    thanks
  4. #4 Re: Harmonic balancer question
    From what I've read there is a very small difference in the flex and balancers between the NA and SC motors. However I've swapped then both ways and run any and all mixes of them w/o issues. Currrently I am running an 2000 L67 flex with a 2007 NA balancer on an 07 NA motor.
  1. Harmonic balancer
    By dezebe1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2014, 10:19 PM
  2. Harmonic balancer
    By Tone5500 in forum General Tech Discussion
    Last Post: 11-13-2013, 08:01 AM
  3. Well there goes my L67 harmonic balancer...
    By jlgp2007nc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 02:44 PM
  4. Harmonic balancer question
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2009, 04:52 PM
