Thread: Fuel Rail
Results 1 to 17 of 17
  1. #1 Fuel Rail
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    This cars fuel rail. The engine came out of a 2004 Chevy Impala SS Indy 500 Edition. My 1999 GTP engines fuel rail doesn't have that little circle thing left of the Boost Bypass Actuator. What is that and what does it do?
    Sent from my HTC6435LVW using Tapatalk
  2. #2 Re: Fuel Rail
    The Boss Iceman6669's Avatar
    Jun 2011
    Just a little fuel reserve thing. Won't make any difference.
    2011 F-150 Yote powered
  3. #3 Re: Fuel Rail
    Aug 2011
    Michigan
    Alright thanks! I was just curious if it would affect the tuning or anything. But if it doesn't change anything, then I am content with that
  4. #4 Re: Fuel Rail
    hangover park IL
    Quote Originally Posted by tomtom123 View Post
    its a pulsation damper and yes it affects tuning since it reduces the fuel pressure pulsation
    GM saw fit to increase the surface area of the dampeners greatly from that design to the L32/26 design but that's due to the worsening of the pulsation effect with the fpr in the tank on a deadhead/returnless system.
    the bigger you injectors the more your fp fluctuates as the pop open and closed.
    you can see the effects first hand with a mech fp gauge on your damperless rails youll see the needle bounce at idle, its travel will be roughly halved when you do the same test with the dampened rails
    consistent fuel pressure means consistent fueling
    ~James~ Psychotic Gearhead
  5. #5 Re: Fuel Rail
    Aug 2011
    Michigan
    Since my car was a 99 and didn't have that, would it be best to swap my fuel rail onto this engine?
  6. #6 Re: Fuel Rail
    hangover park IL
    I would bend over backwards to keep the damper.... get rid of your old rails
  7. #7 Re: Fuel Rail
    Aug 2011
    Michigan
    I guess I just don't understand then. It helps with fuel pressure consistency? That's good, right? But the 1999 GTP had 36# injectors and the 04+ had 33# injectors, iirc. So should I keep these fuel rails and put the 36# injectors in these rails? And I'll have to tune my car to this new damper, right?
  8. #8 Re: Fuel Rail
    hangover park IL
    no you will not need to tune specifically for it but the damper will keep fuel pressure fluctuations from affecting fueling which is good
    the effect is amplified the bigger the injectors so for big builds dampers can be a great addition
    use your injectors with those rails with the damper and you're set
  9. #9 Re: Fuel Rail
    hangover park IL
    and that is technically a series 3 l67 only the Grand Prix got the L 32 that had the stainless fuel logs with the largest fuel rail pulsation dampers and gen5
  10. #10 Re: Fuel Rail
    LaBarge Supercharged sseilmnop's Avatar
    Mercer, Pa
    I get the dampening. But non of us who have purchase modified fuel rail or even billet fuel rails have this. So it's good to have but I've never heard of a push to add this before. Am I missing something.
    Adapters, Phenolic Intercoolers, Supercharger Parts & TVS2300
    http://stores.ebay.com/QualitySuperchargers
  11. #11 Re: Fuel Rail
    hangover park IL
    these are the pulsation dampers inside the l32 rails. you grind off the weld opposite the brazed end and knock out the plug that remains... they are sized for dash 6 rails id...but I install them in dash 8 dash 10 Fatman rails by modifying them.
  12. #12 Re: Fuel Rail
    hangover park IL
    I haven't tried it yet but I'd like to see if you can shove them inside Aeromotive rails
  13. #13 Re: Fuel Rail
    Aug 2011
    Michigan
    So the engine I picked up was a L67 with the Series 3 3800 that just has a Gen 3? Which in Grand Prixs is actually the Series 3 3800 with a Gen 5?
  14. #14 Re: Fuel Rail
    Aug 2011
    'Merica
  15. #15 Re: Fuel Rail
    Aug 2011
    Michigan
    Right. I know what year they switched for Grand Prix's. Just didn't know about the other GM cars, such as the 2004 Impala
  16. #16 Fuel Rail
    Mercer, Pa
    Engine is 2004 Gen 3 supercharger with return style fuel rails.
    GP's only had gen 5. 2004 thru 2007
  17. #17 Re: Fuel Rail
    Aug 2011
    Michigan
    Yeah. Too bad this engine didn't come with a Gen V. Hah
  1. The retainer/clip the secures the fuel line to the fuel rail.
    By Sudden in forum Wanted To Buy - Parts
    Last Post: 06-22-2013, 05:20 PM
  2. Fuel line leak at fuel rail
    By Burbman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2013, 12:43 PM
