Thread: Top Swap Won't Run Right
Page 1 of 3 123 LastLast
Results 1 to 20 of 60
  1. #1 Top Swap Won't Run Right
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    I just did a top swap on my 98 GP GT ran perfect before. Now to get it to start I have to hold the gas down alittle and it doesn't stay running unless i hold the gas. Only code is P0300 for a random misfire
    Heres a video
    2000 GP GT 3.8 NA Stock Engine - Cat, EGR Deleted - K&N Cone - Pulstar Pulse Plug ad1h10 -6k HIDS- LEDS
  2. #2 Re: Top Swap Won't Run Right
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    You're scaring me away from doing mine!
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
    Any pcm changes?
    Which tb did you use?
  4. #4 Re: Top Swap Won't Run Right
    Double check your plug wires. Trust me....I'm pretty sure. You do have some exhaust on it right?
  5. #5 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    The PCM is a gtp w\ a gt trans tune
    I'll check the plugs again
  6. #6 Re: Top Swap Won't Run Right
    Jan 1970
    Maquoketa, Iowa
    What year of PCM?
    Who changed the tune for the trans?
    What injectors?
    What year tb/maf?
  7. #7 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    guy from here from South Daktoa can't remember user
    l67 inj
    99 tb\maf
  8. #8 Re: Top Swap Won't Run Right
    HUDSON
    Why did your temp gauge swign up when the ign. was turn on?
  9. #9 Re: Top Swap Won't Run Right
    Yoga city
    ^this why the sweep?
  10. #10 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    It did that after I switched pcm
    I checked the plugs and got it started for alittle bit still had to hold the gas. after it died I tried to start it again and no go
  11. #11 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    Are the ignition coils stock?
  12. #12 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    yup
  13. #13 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    Let's see. Your having to keep the TB open and your getting a P0300. Sounds like a vacuum leak to me.
  14. #14 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    Sorry forget to say after I switched the around around the p0300 went away and started and had to hold the gas a little but now i can't get it started
  15. #15 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    You check for spark?
  16. #16 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    Yup good blue spark, I can get it to start if i spay some starting fluid in then I can get it to start and run
  17. #17 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    Fuel issue? Maybe FP resistor or pump?
    Make sure the pump winds up with key "ON". Then check fuel pressure at schrader valve.
  18. #18 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    how would I hook a f\p resistor up on a l36 harness, I dont have a pressure gauge with me but if i push the value in it will shoot over the hood
  19. #19 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    Oh, forgot you did the swap. So starting fliud gets it running and there are no other DTC's. HMMMM.
    Still sounds like a vacuum leak. I know it's hard to check for vacuum leaks when it won't idle but maybe someone can help you...one guy with a can of carb cleaner and the other keeping it running at a steady RPM.
    Edited:
    Did you try unplugging the MAF?
  20. #20 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    I'll see if a friend can help tomorrow before work. Yea i tried the maf no change. oh just noticed something the boost gauge doesnt move when it goes into boost
  1. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. pcm swap
    By whiney6 in forum General Tech Discussion
    Last Post: 06-06-2010, 04:14 PM
  4. Cam for a top swap
    By matt5112 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2009, 12:47 AM
