Thread: Injectors
Results 1 to 14 of 14
  1. #1 Injectors
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    I've read tons of information on here about people modding their engines and then dropping to 3.4" pulleys. Even people modding hardcore and dropping to 3.0" pulleys on GenV's, running E85 and all that which is awesome. But before intercooling, at what point should injectors be upgraded?
  2. #2 Re: Injectors
    If you are running them to almost static, they need to be upgraded or if you are swtiching fuel types.
    A scanner or tuning software can monitor the duty cycle of the injectors and if you're at 90-95% you are about to run out of fuel. Figure most 3.4 setups will never need injectors, but somewhere around the 3.2 range can it be an issue.
    E85 should be on 60lbs just to keep it simple.
  3. #3 Re: Injectors
    I break stuff selliott's Avatar
    Kansas City
    I'm running 80s on my e85 setup
  4. #4 Re: Injectors
    Aug 2011
    Michigan
    I may have answered my own question, but more info would be appreciated as well.
    in the "Safely Modding Your 3800" thread, it says anything smaller than a 3.1" pulley will run the stock 33# injectors static. Well, I thought the 1997 - 2003's had 36# injectors? Correct me if I'm wrong.
    I was planning on trying this set up
    3.4" (or 3.3" if my knock allows)
    1.9 Rockers
    SD Headers
    180° t-stat
    AL 104's
    Open Cone Intake
    and an Overkill Tune
  5. #5 Re: Injectors
    Aug 2011
    Michigan
    Quote Originally Posted by selliott View Post
    Thanks guys for the quick information =)
    Wasn't expecting to get answers yet =P
  6. #6 Re: Injectors
    97-03 are good to around a 3.2 usually 04+ need injectors around a 3.4
  7. #7 Re: Injectors
    Aug 2011
    Michigan
    Alright, thanks!
  8. #8 Re: Injectors
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    do you think 42# would be fine for 3.2-3.0 range on genv and at what point do you need a bigger fuel pump
  9. #9 Re: Injectors
    Yup
    04 Comp G.
  10. #10 Re: Injectors
    Or try to find some used 60#s and never worry about it!
    04 Comp G.
  11. #11 Re: Injectors
    Jun 2013
    brookville,IN
    what about fuel pump
  12. #12 Injectors
    Stock is fine for the most part unless it's high mileage then it may be a good excuse to upgrade but generally that guys the upgrade their pumps are upgrading because of e85
    04 Comp G.
  13. #13 Re: Injectors
    Jun 2013
    brookville,IN
    gotcha
  14. #14 Re: Injectors
    Florida
    < Gen V, 3.0, 20* timing, 42.5lb/hr injector, stock fuel pump with the rewire. WOT at 6500rpm duty cycle is around 80%
  1. WTB 60# injectors EV1
    By glendayle in forum Wanted To Buy - Parts
    Last Post: 05-13-2013, 04:47 PM
  2. How are the 42# injectors?
    By $03gp/gt$ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-21-2010, 08:00 PM
