Thread: Cold air intake
Results 1 to 10 of 10
  1. #1 Cold air intake
    Nov 2008
    wichita
    Ok I got my CIA, and went home to install during lunch. I popped my hood and was getting rdy to it, and way different then throwing one on a civic lol.
    Here is the Issue.
    1 there is a box connected to my stock intake, Looks like a MAF or something, What is this and do I move it or what no place on my cia to put it.
    2 according to instructions I need to Relocate a CPU is this true? inside the air filter box? does anybody have a pic of this part. it looks like the guy that had before me moved it behide the front grill, I just want to see a pic to make sure its the right part.
    Or how about I pay a wichita person to come over and learn me on this car. lol why cant everything be easy like hondas
    MOD:AL104s,CAI,DHP TUNED PCM MOD I have not installed:180 Thermostat,3.4 pulley, boost gauge, A/F Ratio Gauge MOD I HAVE NOT ORDERED YET: DP,
  2. #2 Re: Cold air intake
    Donating Users blowfishRus6's Avatar
    g.a.
    the airfilter is in that box. remove it. the pcm is also in there. remove that also. if you have a cai without a box you can ziptie the pcm in place under the factory box.
    just start pulling stuff out/off. youll figure it out
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: Cold air intake
    the MAF is in the throttle body. the only thing you have to worry about doing is strapping your PCM down so it doesn't flop all over the place and moving the air intake sensor from the stock location on the box to the tubing that you bought. you can get a pcm tray, but you really dont need it if you dont feel like paying for one.
  4. #4 Re: Cold air intake
    Nov 2008
    wichita
    lol ok
  5. #5 Re: Cold air intake
    Barksdale AFB, LA
    Quote Originally Posted by redrunner View Post
    I guess you're talking about the airbox. That's what your stock air filter is in. It is not used with the new CAI.
    If you're talking about the intake air temp sensor, then there should be a hole in your new intake for it. If not, make one.
    Here is a pic of a PCM:
    http://www.zzperformance.com/products_img/182_1.jpg
    There's no way it was relocated behind the grille. No point, and it would be a wiring mess.
    These are a lot easier to work on than import garbage. Welcome to a real car.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Cold air intake
    youll find more and more as you take things apart that half the stuff you take off you dont need to put back on. there are plenty of small brackets and extra parts that i have just left off because it makes it look nicer or it makes it easier for me to work on later.
    i have a franken-prix.
  7. #7 Re: Cold air intake
    Nov 2008
    wichita
    No the thing on my intake pipe looks like a Mass air flow sensor or something. I have a the hole for the air temp sensor. This is different, Also do I need to get a Coolant Recovery Bottle or relocation anything else to make fit
  8. #8 Re: Cold air intake
    Barksdale AFB, LA
    Picture?
  9. #9 Re: Cold air intake
    Nov 2008
    wichita
    Quote Originally Posted by Sabrewings View Post
    Picture?
    ok give me a day and i will show you a pic
  10. #10 Re: Cold air intake
    Aug 2008
    SOUTH TEXAS
    U sound like me, when i bought my first mod on my gp.
    lol @ ur sig!Cool.
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  1. Help-cold Air Intake
    By sUpErClEaNbLaCkMaChInE in forum General Tech Discussion
    Last Post: 01-29-2009, 12:36 AM
  2. K&N Cold Air Intake
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2008, 07:39 AM
  3. Cold Air Intake
    By TCO in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2008, 11:02 PM
