Thread: GTP CompG with L26 Bottom HELP!!!!!
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 GTP CompG with L26 Bottom HELP!!!!!
    GTX Level Member crbquist's Avatar
    Massachusetts
    Quote Originally Posted by sseilmnop View Post
    You are recommending throwing away his current motor and starting over with used L67 L32 motor. Have you looked and priced one lately?
    They want $1,500 for one with 150,000 miles.
    No. Never said that once. All I was implying is that, to me anyway, they are no more than a cheaper solution when replacing a 3800 and that I myself would stick to a supercharged bottom end for reliability concerns. To each their own, I've heard of guys blowing L26's on stock pulleys. They have the weakest rods in the 3800 platform.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #22 Re: GTP CompG with L26 Bottom HELP!!!!!
    Mercer, Pa
    I'm pushing hard because he asked for help fixing his car and your telling him you wouldn't use the NA block. It's just your opinion and it doesn't fix his car.
    As far as we know there is nothing wrong with the block.
  3. #23 Re: GTP CompG with L26 Bottom HELP!!!!!
    Massachusetts
    I know, I got ya.. Maybe I was a bit harsh and shouldn't have chimed in. I wish him the best of luck with his build.
  4. #24 Re: GTP CompG with L26 Bottom HELP!!!!!
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    The higher compression ratio of an L36 or L26 bottom end makes it harder to run over 10-11psi, so some moderation in terms of boost levels need to apply. This is less of an issue with cammed or intercooled setups. Otherwise, reliability wise, not an issue running an L36/L26 block. Some of my old builds are 7-8 years and counting on L36 blocks.
    Email all inquiries to willoverkill@gmail.com!
  5. #25 Re: GTP CompG with L26 Bottom HELP!!!!!
    I swear someone said that zzp uses a l36 in their car with the stock bottom end.
  6. #26 Re: GTP CompG with L26 Bottom HELP!!!!!
    Jan 2014
    Kentucky
    I Have been doing some research on those bottom ends Rods and such. I know that the L26 that im fixing is out of an 2006 Grand Prix GT 70,000 miles. I think those L26 have the strong Rods Powder Metal I think. I think it was 04 and back that didn't have those type of rods. This is an article I found: The Series III motors include many changes. The upper intake manifold is now aluminum on the naturally aspirated models. Intake ports are mildy improved, 1.83" intake valves (instead of 1.80" as on Series II) and 1.52" exhaust valves were introduced in 2003 engines, just before switching to Series III. Electronic throttle control is added to all versions, as is returnless fuel injection. Stronger powdered metal sinter forged connecting rods are used in 2004+ supercharged, and 2005+ naturally aspirated engines, instead of the cast iron style from Series II engines. Emissions are also reduced. In 2005, it was the first gasoline engine in the industry to attain SULEV (Super Ultra Low Emissions Vehicle).
    Also note that Series III engines are the base for any 3800 produced for the 2004 year and up. This means the same block, heads, & connecting rods apply to any remaining Series II engines made after 2004 also. The difference is that Series III engines received the new superchargers (Generation 5 - Eaton m90 - if equipped), intake manifolds, fuel systems, and electronics.
    I am new with the 3.8s, Correct me if any of the above is not a fact. I REALLY DO THANK YOU GUYS FOR YOUR TIME AND INPUT.
  7. #27 Re: GTP CompG with L26 Bottom HELP!!!!!
    Jan 2014
    Kentucky
    Soon as it warms up and I get it put to gather I will let you guys know how everything went.
  8. #28 Re: GTP CompG with L26 Bottom HELP!!!!!
    i wouldn't worry about the rods, both have been used, both can break if heavily modded.
  9. #29 Re: GTP CompG with L26 Bottom HELP!!!!!
    Massachusetts
    Quote Originally Posted by jewell83 View Post
    This has been argued upon for quite some time now.. Some say the series 3 is stronger than the series 2 and vice versa. From what I've researched over the past few years, I'd say the L26 is the weakest of the bunch and L67 is the strongest.
  10. #30 Re: GTP CompG with L26 Bottom HELP!!!!!
    SE Level Member FASGP's Avatar
    Toronto ON
    I have also seen some pretty vicious L26 powered 15+psi turbo cars hold up just fine for a very long time after the host L67 went for a crap. I think the thread is sort of off topic now though. The OP wanted to know what to do, and he should be just fine with his L32 or L67 top end on his L26 bottom end without changing the whole thing.
    Vtec...All the lag and none the turbo...it's like waiting for bad sex
  11. #31 Re: GTP CompG with L26 Bottom HELP!!!!!
    Jan 2014
    Kentucky
    I got my comp g up and running today. She runs great no issues or leaks so far. I did hook up my obd2 and got a #6cylinder missfire. It don't feel like it has a miss but im going to search into this. Trans shifts awesome changing all fluids as we speak.
  12. #32 Re: GTP CompG with L26 Bottom HELP!!!!!
    Just double check your plugs and wires.
    Sent from A Galaxy Far Far Away........
  13. #33 Re: GTP CompG with L26 Bottom HELP!!!!!
    Jan 2014
    Kentucky
    I put new AC delcos in and wires I will pull the plugs in a bit and check em out.
  14. #34 Re: GTP CompG with L26 Bottom HELP!!!!!
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    ummm, is 898 WHP enough for you? Because thats what ZZP did on a stock N/A block. Only limited by the trans.. Seems to me our N/A blocks will put up with plenty of power.
    04 GTP -HAI, 1.9 rockers.
  15. #35 Re: GTP CompG with L26 Bottom HELP!!!!!
    Jan 2014
    Kentucky
    I really Love the power it makes. They have the lower RPM power and followed by the boost they will pin you to the seat. It reminds me a lot of my dirtbike days how those 2 cycle motocross bike have that supper strong power band, well these cars are like that X10000. LOL. I am really enjoying my car. I traded my 96 Z28 6Spd for this 04 comp G with L26 Lower L32 Upper. I have put some money into it but it is so worth it... I think these cars will run with or out run the z28s, my opinion.
  1. Replacing L67 bottom end for L26 bottom end
    By OcalaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2013, 06:05 PM
  2. Are the compg gtp's faster than the non compg gtp's?
    By GMCARS4LIFE in forum Off Topic Discussion
    Last Post: 03-07-2011, 09:19 PM
  3. bottom swap, or how i learned to rebuild the bottom end completely
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:37 AM
