Thread: GTP CompG with L26 Bottom HELP!!!!!
Results 1 to 20 of 35
  1. #1 Re: GTP CompG with L26 Bottom HELP!!!!!
    SE Level Member FASGP's Avatar
    Toronto ON
    I run L26 with L67 heads and GenV on top. Just check the surfaces, and redo proper gaskets on the top half, and you should be golden. The L26 makes a real nice difference over the L32 or L67 bottom end...so enjoy that. Welcome to the 3800 family...
    Vtec...All the lag and none the turbo...it's like waiting for bad sex
  2. #2 Re: GTP CompG with L26 Bottom HELP!!!!!
    GTX Level Member crbquist's Avatar
    Massachusetts
    Quote Originally Posted by FASGP View Post
    I'd run an l67 or l32 over an l26 any day. Not sure what is so special about an l26... Just a cheaper solution when replacing a 3800.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  1. Replacing L67 bottom end for L26 bottom end
    By OcalaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2013, 06:05 PM
  2. Are the compg gtp's faster than the non compg gtp's?
    By GMCARS4LIFE in forum Off Topic Discussion
    Last Post: 03-07-2011, 09:19 PM
  3. bottom swap, or how i learned to rebuild the bottom end completely
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:37 AM
