None really unless you have fat forearms like i do...
then roll up them sleves
Losen up the front header first, then remove the dog bones
and roll the motor forward, Tie it forward to the front suport
If you are not sure of the fireing order then before you remove the plugs
tape them were they go.
They were pretty easy to install, and my only hard part was cutting the
pipe after the flex and installing the new flex...
I did go down to my local shop to put it up on the hoist
but that was because it was raining and $50.00 bucks compared
to laying on the ground in the cold and rain---> = $50.00 bucks
well spent
I was at first thinking i would have to remove the TB and such
but you will see as you go it is not that bad at all...
