Thread: Alarming Amount of KR?!?
Results 1 to 9 of 9
  1. #1 Alarming Amount of KR?!?
    Jan 2014
    Bay Area CA
    So I just purchased the torque app and figured I would chekc for KR on my 100% stock 56,000 mile 1999GTP. Well I am a little scard to say the least.
    Standing start to the 1-2 shift I saw a peak of 7* of KR. . I thought stock GTP's at most should be about 2-3*.
    I plan on doing a complete tune up but ****...
  2. #2 Re: Alarming Amount of KR?!?
    Florida
    Its not too unusual to see it yay high like that. Some people stock have 6-8* of knock. Just get some flow mods.
  3. #3 Re: Alarming Amount of KR?!?
    Jan 2014
    Bay Area CA
    Sounds good. SD headers should be delivered today. Will test KR afgain after that and confirm if it is lower and by how much.
  4. #4 Re: Alarming Amount of KR?!?
    A tune up and running 91+ octane can help.
  5. #5 Re: Alarming Amount of KR?!?
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    What pids are you using for the KR?
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  6. #6 Re: Alarming Amount of KR?!?
    Jan 2014
    Bay Area CA
    The Gm Opel Vauxhaul one.
    I run 91 crappy california gas.
  7. #7 Re: Alarming Amount of KR?!?
    Willoughby, Ohio
    you will see KR on a stock gtp, the tune up, an intake, and the headers will do you wonders
  8. #8 Re: Alarming Amount of KR?!?
    Feb 2009
    flintnasty MI
    check your total timing too, with 7kr you will have 9 degrees commanded timing at wot.
  9. #9 Re: Alarming Amount of KR?!?
    Jan 2014
    Bay Area CA
    Total timing was at about 10-11
    Sent from my SCH-I535 using Tapatalk
  1. Estimated amount of hp I will make?
    By CoolblueGTP2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2013, 09:17 AM
  2. What amount of KR is acceptable?
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2013, 05:56 PM
  3. unbelievable amount of sludge in oil pan
    By john cola in forum General Tech Discussion
    Last Post: 10-22-2012, 08:34 AM
  4. Drain and refill amount
    By TEK310 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-10-2012, 01:18 AM
  5. Have a small amount of cash. DP, HV3, or PLOG?
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2009, 09:45 PM
