Could it have warped block and still be running fine performance wise?
it can run fine, but that needs to be fixed. coolant leaks dont get better, they get worse.
id make sure that middle cylinder is the same on compression as the other 2 back there. hell check am all.
I dont plan on driving it like that i meant for diag purpose, could a engine w/ warped block still run fine? I would think it would have Miss or would be bad running overall
if the cylinders got full compression sure. one of the cooling ports are leaking maybe.
if the head bolts are tight and your sure its leaking out of the heads to block area, take the head off. check it out.
What would i be checking for on heads it has like 20 miles on them since it was at the machine shop gettin resurfaced & valve stem seals
What else could it be leaking from in the back head area. I know its not the heater hose's or freeze plugs back there that are leaking
thats about it. you can put a cooling system pressure tester, and force it to leak so its not hot and you can get a better look or your hand in there safely.
Do not help this guy with anything !!! He sent me torn cone Bose speakers and ones that don't even work.
He scammed me out of money and will not return my calls or texts.
Do not help him !! He's a liar and a thief and an asshole !!
