Thread: Oil... oil... oil... gimmie your take on oil!
Results 1 to 20 of 21
  1. #1 Oil... oil... oil... gimmie your take on oil!
    Banned
    Jan 2013
    maryland
    Which oil brands do you guys run with your modded setups or stock? Do you guys prefer thicker? 5w30 10w30 20w30 what's a good choice any suggestions are greatly appreciated changing my oil before startup om my build need some reviews
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #2 Re: Oil... oil... oil... gimmie your take on oil!
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    I've used Valvoline 10w-30 and changed it every 3000mi on my stock 00 GT. Ive heard that as long as you change it every 3,000mi there isn't a huge difference between the brands.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  3. #3 Re: Oil... oil... oil... gimmie your take on oil!
    Antioch, IL
    walmart special 5-30
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: Oil... oil... oil... gimmie your take on oil!
    what ever is on sale, if you change your oil every 3,000 miles does it really mater?
  5. #5 Re: Oil... oil... oil... gimmie your take on oil!
    Banned
    Jan 2013
    maryland
    So any oil is good oil?
  6. #6 Re: Oil... oil... oil... gimmie your take on oil!
    Oct 2013
    NC
    Now days all oils are good. Just make sure it has the API Service Symbol "Donut" and Certification Mark "Starburst"—help consumers identify quality engine oils for their gasoline and diesel-powered vehicles.
  7. #7 Re: Oil... oil... oil... gimmie your take on oil!
    Oct 2013
    NC
  8. #8 Re: Oil... oil... oil... gimmie your take on oil!
    oil is oil in my book. synthetic gets just as dirty after 3,000 miles letting it go longer dont make sense to me.
    so i change it every 3,000 miles and buy whats on sale with a filter. about 22 bucks most of the time. get what grade oil it says on your oil cap and your fine.
  9. #9 Re: Oil... oil... oil... gimmie your take on oil!
    GT Level Member RegalGS98s's Avatar
    NJ
    For longevity and performance I use Mobil 1 5w-30 or 10w-30 depending on the season. I noticed a difference going from conventional in performance. Expect more leaks and don't try going back to conventional after you switch though. Usually don't have any issues with the engine, transmissions hate me though .
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  10. #10 Re: Oil... oil... oil... gimmie your take on oil!
    Jul 2012
    Clayton,NC
    If you can find a oil that is API service SL rated they have higher levels of ZDDP which is the main anti-wear additive in oil. I use valvoline synthetic vr1 10-30 and wix filter every 3k.
    98 gtp- cammed intercooled slowness
  11. #11 Re: Oil... oil... oil... gimmie your take on oil!
    Aug 2013
    McDonald PA
    What's the diff between 5w-30 and 10w-30?
  12. #12 Re: Oil... oil... oil... gimmie your take on oil!
    About 5w.
  13. #13 Re: Oil... oil... oil... gimmie your take on oil!
    But in all seriousness it has to do with the cold weights of the oil and warm weights. As in the viscosity of it I believe. The 5w-30 starts off thinner than the 10w-30 but when warm they are the same.
  14. #14 Re: Oil... oil... oil... gimmie your take on oil!
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    I believe its the winter viscosity rating. 5w being thinner than 10w - don't quote me but I am pretty sure thats the difference I run 5w in the winter 10w in the summer
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  15. #15 Re: Oil... oil... oil... gimmie your take on oil!
    Jan 2009
    Tallahassee, FL
    I just run 10-30 synthetic from a name brand and change it after the oil life starts getting low.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  16. #16 Re: Oil... oil... oil... gimmie your take on oil!
    Aug 2013
    McDonald PA
    Well why not run what's recommended? I need to do an oil change and I want to know what's better viscosity for my motor
  17. #17 Re: Oil... oil... oil... gimmie your take on oil!
    You'd be safe running either But when it gets colder the 5w-30 isn't as thick so when you start your motor it will lubricate better right away.
    If I were you Id stick with the 10W-30 if that's what is suggested. Unless you want to change it again when temps warm up.
  18. #18 Re: Oil... oil... oil... gimmie your take on oil!
    Oct 2013
    NC
    Changes with the climate/temp. Should be in your owners manual if you have one.
  19. #19 Re: Oil... oil... oil... gimmie your take on oil!
    GT Level Member WolvesSoulZ's Avatar
    Québec
    I just buy the cheapest on rebate 5w-30 I can find, usually get a 5L jug for 15$ taxed. Change it every other 2500-3000 miles. Oil is oil.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  20. #20 Re: Oil... oil... oil... gimmie your take on oil!
    Apr 2012
    Goderich, Ontario
    I only use Mobil 1 10W 30 with a Napa gold filter and change it every 5,000kms. I usually buy a couple jugs when it's on sale.
    -Paul Walker
