Thread: Motor swap
Results 1 to 4 of 4
  1. #1 Motor swap
    Jun 2011
    Tempe, Az
    If have a 98 gtp with a bad motor. I was wondering if I could put a non super charge 3.8 motor in it. Will it work or do I need to change anything??? Please help
  2. #2 Re: Motor swap
    Use everything from the heads up on the GTP engine the bottom end will work from a non SC engine and actually make a little more HP thanks to the higher compression of the NA engines. You will have to use everything from the heads on up from the GTP engine though because the heads are different also. Going to need to use the GTP belt setup too. Other than that everything will bolt together just fine.
  3. #3 Re: Motor swap
    Jun 2011
    Tempe, Az
    I was thinking about just putting the non supercharge motor... would that motor work with the tranny I have?
  4. #4 Re: Motor swap
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    The motor can work but it will need a tune. Some wires are different but just one connection if i remember correctly. it isn't as easy as putting it in and hooking it up and start it and run great.
    If You Cant Hear The Whine You're Too Far Behind...
  1. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  2. ? about a motor swap
    By krimsonwolf in forum General Tech Discussion
    Last Post: 07-23-2010, 12:38 AM
  3. Motor swap
    By tracker1925 in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-26-2010, 03:44 PM
  4. Motor swap
    By redgp89 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2009, 01:00 AM
  5. Motor Swap
    By Dohner in forum General Tech Discussion
    Last Post: 08-07-2008, 10:59 AM
