Thread: Engine swapping help!!
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 119
  1. #81 Re: Engine swapping help!!
    i dont think the cam being off a would cause over fuel at start up. the fueling starts when you turn the key, it primes the cylinders first. then you crank it then the injectors start to work.
    so maybe its getting over primed for some reason.
  2. #82 Re: Engine swapping help!!
    I don't thing that's the problem. That shouldn't cause any fuel issue.
  3. #83 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    I know guys it doesn't make sense... any take on what to stop the over fueling? Any ideas?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  4. #84 Re: Engine swapping help!!
    fuel pressure regulator
  5. #85 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    I know ds muts its leading to that tps hasn't been replaced neither im doin that as soon as i get it to my house
  6. #86 Re: Engine swapping help!!
    those are easy to change im told.
  7. #87 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Tps? Its just 2 screws or the fuel pressure regulator
  8. #88 Re: Engine swapping help!!
    both are easy
  9. #89 Re: Engine swapping help!!
    fpr is in the round part of the fuel rail with the vac line on it.
  10. #90 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Yeah its easy I know what the for is thanks guys
  11. #91 Re: Engine swapping help!!
    Dec 2010
    DMV
    Hope you get it up and running bro!
    Sent from my HTC One using Tapatalk
  12. #92 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Im goin to man just the little things
  13. #93 Re: Engine swapping help!!
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Do you have a mass airflow sensor you could swap in just for shiz and giggles?
    When my MAF started acting up it was throwing so much fuel my exhaust would glow red all the way to the mufflers!
    Just a thought.
    Sent from Not so smart smartphone
  14. #94 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by Twizted 1 View Post
    Just a thought.
    Are you serious thats the same thing happening with my car man smh so much fuel in the spark plugs im running thru spark plugs like a mutha
  15. #95 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    P0118 p0122 p1115 p1122 p1406 these are the codes im gettin coming from the aeroface gauge egr delete tps low coolant
  16. #96 Re: Engine swapping help!!
    Banned
    Jan 2013
    maryland
    Its Def something with the fuel relay resistor or fuel pressure relay im sure of it which are easy tasks
  17. #97 Re: Engine swapping help!!
    Did you read the description of the P0118?
    Symptoms of a P0118 could include:
    Very poor fuel economy
    A no start condition
    Vehicle may start, but run very poorly, blowing black smoke, running very rough and misfiring
    Illumination of MIL
    You have 2 codes for the engine temp sensor and 2 for the TPS btw.
    P1115
    Possible causes
    - Faulty Engine Coolant Temperature (ECT) sensor
    - Low engine coolant level
    - Engine Coolant Temperature (ECT) sensor harness is open or shorted
    - Engine Coolant Temperature (ECT) sensor electrical circuit poor connection
    - Faulty engine coolant thermostat
    I would replace the tps and the engine temp sensor, I don't think it has anything to do with the fuel resistor or relay. Also check the wiring to the engine temp sensor, it comes very close the crossover and it might have gotten melted on it, I have mine wrapped with wire wrap.
  18. #98 Re: Engine swapping help!!
    Jul 2013
    Summertown Tn
    X2! Fix your known problems first.
    Its not going to be the relay or resistor.
  19. #99 Re: Engine swapping help!!
    Minnesota
    Did you fix the TPS?
  20. #100 Re: Engine swapping help!!
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Exactly what I been saying lol. Had to come back from the dead to reasure IT IS NOTHING WRONG WITH MY ENGINE. That shop is trying to get some quick bucks. We all saw the thread I made on here when I put that engine together. No way in hell the cam amd sprocket dots are misaligned....i ran 12s with that motor. Everything from the lim and up are swapped over from the stock motor lol. But we will replace that tps and try and fix the LITTLE KNOWN ISSUES with that car this saturday and ACTUALLY test drive the car. Jay make sure you get that rack and pinion fixed.
    Sent from my SGH-M919 using Tapatalk 2
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  1. Top swapping
    By stockGTforlife in forum General Grand Prix Discussion
    Last Post: 09-26-2013, 11:46 AM
  2. swapping
    By coreysGTP in forum Introductions/Noob Questions
    Last Post: 12-28-2012, 10:35 PM
  3. engine swapping question
    By PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 10:43 PM
  4. Swapping Engine
    By Redgtp1999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 08:06 PM
