How dose it sound when you start? Dose it try to stay running before it cuts off? What color is your smoke? White, Black, or Blue? Try the cheap things first, check your filters.
Is it approximately three seconds?
When the car cuts off?
Sent from my HTC One using Tapatalk
2000gtpbt it sounds good smoke is white I guess filters been replaced oil filter changed oil twice fuel I haven't yet
Starts great when I first bent the 85 tab for the fuel relay this is the vid: http://i1104.photobucket.com/albums/...psb36637d1.jpg codes p0121 for TPS came on
After I changed throttle body gasket and charged my already f***ed battery:
http://i1104.photobucket.com/albums/...ps6997e7c7.jpg no codes neither what could it be?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Try starting out with the tps unhooked
Ok I'll try thanks dsmuts
Started with tps unhooked same thing cranks then shuts off in secs smh.. still nuthin wats the issue? checked for bad connections no issues smh what else could it be guys? Vid 1 the motor was fine no issues .. smh
if you try giving it gas it still dies?
Yeap nuthin happens been doin that since the first startup
Any sensors bound to break or malfunction after engine swap on these motors? I mean I tryna figure every issue its just not makin sense what could it be?
Did you use your original coil packs and control module....or one that was on the replacement engine? Control modules usually completely die, but, I have come across a couple that were still trying to work.
Check the transmission connections.
Coil packs are from replacement engine I'll swap from my old engine.. if they were dead coils the car would misfire terribly or not come on right? 02navyblue trans connections are fine and connected judt tried same issue car shuts off in a few secs after start up.. smh I'm running out of ideas
I forgot to reconnect my trans connection once and it started for about one second and shut off, that's why I suggested it. There are two connections visible under the hood.
So I should replace the whole assembly?
I would use what I knew worked for certain. Should only take a couple minutes to swap out.
Just for kicks, do you have a different key? Like a valet key?
I know you said the security light doesnt flash but give that a try and or do the re-learn.
I agree try re-learn, and grounds. Haha I know this sounds stupid but try putting in some more gas. At this point any thing is worth a try.
