Thread: 6 year old problem fixed. Now runs bad
Results 1 to 10 of 10
  1. #1 6 year old problem fixed. Now runs bad
    GT Level Member m17davis's Avatar
    Orland Park, IL
    So since I bought my car 6 years ago I have had a bad BBV. Until yesturday. I replaced it with one I had laying around. Ive always made 4 psi of boost. Now I make around 10. When I get towards 8 and 9 psi it starts stuttering and almost died once. Is my AFR off? Im not sure. I need to get the o2 bung welded in. Any ideas?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: 6 year old problem fixed. Now runs bad
    Maybe its a misfire.
    How old are the spark plugs??
    Or maybe its even a coil pack or the ICM if indeed its a misfire.
  3. #3 Re: 6 year old problem fixed. Now runs bad
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Does it misfire worse the higher the boost builds?
    If so then i would guess that it has to do with plugs, wires, coil packs, maybe ICM.
    The more boost there is the more resistance there is to the spark jumping the plug gap. Maybe chack your plug gap
    I went NA when a whore left -$300 in my bank account.
  4. #4 Re: 6 year old problem fixed. Now runs bad
    Orland Park, IL
    The plugs and wires are like 4 years old. Yes. The higher I am into boost the worst it gets.What should they be gapped to? If you had to choose what plugs and wires. Which do you think are the best? Do msd coils have a bad reputation?
  5. #5 Re: 6 year old problem fixed. Now runs bad
    Stock coils, ac delco wires and some copper 605's is what I would run.
    MSd coils are known to cause problems down the line.
  6. #6 Re: 6 year old problem fixed. Now runs bad
    Orland Park, IL
    Who sells the copper 605's? I can't find them anywhere. And what would you recommend gapping them to?
  7. #7 Re: 6 year old problem fixed. Now runs bad
    Any napa or autozone should carry autolite copper plugs, I run a .055 gap.
  8. #8 Re: 6 year old problem fixed. Now runs bad
    Feb 2009
    flintnasty MI
    plugs and plug gap is a good start... Usually i find problems with the coils or wires and Ive troubleshooted the problem many times
  9. #9 Re: 6 year old problem fixed. Now runs bad
    Orland Park, IL
    The day after tomorrow Im going to try new plugs and wires. ill let yuh know thanks
  10. #10 Re: 6 year old problem fixed. Now runs bad
    Orland Park, IL
    plugs didn't change anything. just ordered ac delco wires. ill get them monday. if that doesn't work ill change out the coil packs. after that I don't know what to try. any ideas?
  1. I stumped. Idles and runs ruff. Codes P0300 P0135. New Cat Last year. Help
    By siwittschulte in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-27-2012, 09:09 AM
  2. Weird problem after i though i fixed it...
    By 73pontiac in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-31-2011, 10:43 AM
  3. a/c mode problem fixed!!!
    By Randy GP in forum General Tech Discussion
    Last Post: 10-16-2010, 01:57 PM
  4. My stalling problem not fixed!
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-02-2010, 05:22 PM
  5. **FIXED!** Fixing One Problem Created Another...
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-09-2010, 08:31 PM
