Thread: what kind?
Page 1 of 3 123 LastLast
Results 1 to 20 of 53
  1. #1 what kind?
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    ok ive read the what is octtane sticky and also read the comments,ive seen diffrent opinions,some say the 3.8 sc will be fine with 87 gas in them,some say it will screw it up,some say it will be ok as long the pcm isnt tuned,some say it will knock and chip a piston or something,ive also heard that the 04 was redesigned to run 87 cause the pcm is factory tuned to,im VERY paranoid that it will blow my car up,so far 87 has did good,what signs do i need to look for that it may be doing harm,im wanting to buy a 04+ gtp and dont want to screw it up by putting 87 gas in it,i know they ''say'' premium only but in reality will it kill it,i know im not the only one that uses 87 and pretty sure the previous owners didnt either and at 198xxx it seems to be good to go,can i get some clear answers,thanks
  2. #2 Re: what kind?
    GTP Level Member buickman104's Avatar
    NYC
    Scan the car and see how much knock you get on regular vs premium.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: what kind?
    Jul 2010
    ok what is it suppose to be at?
  4. #4 Re: what kind?
    Jul 2010
    what do you run?
  5. #5 Re: what kind?
    Omaha, NE
    READ THE OWNERS MANUAL!
    The manufacturer doesn't reccomend octane ratings for ****s and giggles.
  6. #6 Re: what kind?
    Jul 2010
    Ok as I stated ^^^ I said I know it says premium
  7. #7 Re: what kind?
    Omaha, NE
    I don't understand why you're trying to get away with running 87. Please elaborate on the purpose of this thread.
  8. #8 Re: what kind?
    Jul 2010
    Because I wanted to know if it'd be ok,I've heard numerous rumors and just want to know the truth,is the 04+ really redesigned to run it??,I want to know signs to look for because I'm looking for another one
  9. #9 Re: what kind?
    Omaha, NE
    Do you have a scan tool? You would want to look for Knock.
  10. #10 Re: what kind?
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    PREMIUM ONLY! Do not run 87 unless you plan to replace your engine in the near future.
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  11. #11 Re: what kind?
    Jul 2010
    Not yet i will soon,idk what it's suppose to be?
  12. #12 Re: what kind?
    Omaha, NE
    Quote Originally Posted by 94grandprix View Post
    Ideally, 0* KR is what you want.
    Factory is about 2-3* on 91 octane 97-03. Most 04+ seem to read a little higher due to "false knock".
  13. #13 Re: what kind?
    Jul 2010
    Boostengtp,is that 97-08 or 97-03?
  14. #14 Re: what kind?
    Jul 2010
    So I'll run 91 for now on and kr needs to be 0 or 2-3,what if it isn't?
  15. #15 Re: what kind?
    Omaha, NE
  16. #16 Re: what kind?
    Dude..
    Run premium aka 91 or 93. No matter if it's a 04 or a 97-03 they both will go boom if you continue to run unleaded. Knock is your biggest enemy! Well aside from our ****ty transmission.
    Would you rather spend a few more bucks feeling up or spend more then that replacing your motor ?
    04 Comp G.
  17. #17 Re: what kind?
    Omaha, NE
    You run leaded gasoline? Do you drive something from the 40s?
  18. #18 Re: what kind?
    87 I meant. It's 4am expect errors
    04 Comp G.
  19. #19 Re: what kind?
    Jul 2010
    Ok I just wanted to clear things up,does this apply to na to or just sc?
  20. #20 Re: what kind?
    Jul 2010
    I knew what you meant
  1. Be kind, I'm new. :)
    By Kilroy in forum Introductions/Noob Questions
    Last Post: 03-07-2013, 07:42 AM
  2. One of a kind '02
    By RegorHtims in forum Off Topic Discussion
    Last Post: 03-30-2011, 11:52 PM
  3. What kind of oil?
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2009, 12:57 PM
  4. what kind of mpg are you getting?
    By PolishedandWaxed in forum General Tech Discussion
    Last Post: 09-16-2009, 05:36 PM
  5. what kind of oil?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2008, 07:37 PM
