Thread: Header Install ran into some problems
Results 1 to 10 of 10
  1. #1 Header Install ran into some problems
    Banned
    Jan 2013
    maryland
    Ok guys ran into some problems with the headers... first off they are speed daddys I wanted to install everything to the front manifold to the rear was ok.. until.. the flex downpipe and o2 extension bolts were all rusted any ideas on takin em off? Could I pull the whole assembly out?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #2 Re: Header Install ran into some problems
    Florida
    PB Blaster and a torch are your best friend. Heat the bolt/nut for a minute or so, then soak with PB, repeat unti desired results are achieved.
    And yes, you should be able to pull the whole rear section out, though it is much easier pulling it out 1 piece at a time.
  3. #3 Re: Header Install ran into some problems
    The Boss Iceman6669's Avatar
    Jun 2011
    I used a hack saw and cut mine in half.
    2011 F-150 Yote powered
  4. #4 Re: Header Install ran into some problems
    Banned
    Jan 2013
    maryland
    Thanks I'll try that
    Quote Originally Posted by Iceman6669 View Post
    Where did you used the hack saw at?
    Down near the flex? Or a little up close the o2 extension
  5. #5 Re: Header Install ran into some problems
    Jun 2011
    I cut mine right where it started feeding back. Right at the angle after the drop.
  6. #6 Re: Header Install ran into some problems
    Jun 2011
    kind of an idea
  7. #7 Re: Header Install ran into some problems
    Banned
    Jan 2013
    maryland
    Iceman thanks!
  8. #8 Re: Header Install ran into some problems
    Been there.. sawzall'd that
  9. #9 Re: Header Install ran into some problems
    Banned
    Jan 2013
    maryland
    Billboost check your pm
  10. #10 Re: Header Install ran into some problems
    Checked my pm. Then suggested we move to chat.
  1. Header Install
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2010, 05:22 PM
  2. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  3. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
  4. my header install needs help
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 04:57 PM
  5. OBX Header Install is Done!!
    By Uno99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:43 PM
