Thread: Intermittent idiling around 2k & other Stuff
Results 1 to 4 of 4
  1. #1 Intermittent idiling around 2k & other Stuff
    Feb 2008
    Abingdon
    Hey All,
    Yesterday while at a stop light, I experienced my car seemed to be idiling rathr hard. So I slip her into netrual and notice that she's idiling @ 2k rpm. So I quickly turned off and re starte the car only to notice that she's idiling normal again. After that, Inoticed that this has been occuring the rest of the evening. When I got home and parked I slipped in park and kept the car running to see if there was something going on with the throttle only to see nothing. I did clean the EGR and the IAC valves about a week ago. A month ago I got a SES code for the EGR that's why i cleaned it as well as the IAC. Oh! one other thing. Since that day I cleaned those two valves I noticed that during starts, i have to tap the throttle a little just to get her started. Once i do that, she seems to be running ok. Any correlation? lil help here please. Sry 4 all da bndwdth. Thanks in advance.
    Derrick
    1999 GTP
  2. #2 Re: Intermittent idiling around 2k & other Stuff
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Sounds like an IAC problem to me, what did you clean it with?
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Intermittent idiling around 2k & other Stuff
    Feb 2008
    Abingdon
    i think i used throttle body cleaner or it could have been contact cleaner. when i get home i will verify. was that to harsh for the IAC valve?
  4. #4 Re: Intermittent idiling around 2k & other Stuff
    SE Level Member gixer2000's Avatar
    Braintree, ma
    Mass Air Flow Sensor
  1. Intermittent Engine Stalling Problems
    By BADAZGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-23-2010, 10:46 AM
  2. 97 Grand Prix GTP with Intermittent #4 Cylinder Misfire
    By srlash in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2009, 10:00 PM
  3. Intermittent Engine Stalling Problems
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-16-2008, 07:59 AM
  4. Help!! '01 GTP misfiring/idiling rough at startup!!
    By fatride99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2008, 06:20 PM
