Thread: Temps rise when idling 15°-20°
Results 1 to 15 of 15
  1. #1 Temps rise when idling 15°-20°
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    I recently had to back flush my heater core several times as I had lost heat due to gunk buildup in the core.(it was doing this before the backflush just wasn't sure if I was contributing to the temp fluctuation) That issue is now resolved but ever since doing so my temp gauge has reached the halfway point when idling sometimes just above the halfway mark and once I start driving again it levels off back down to around 170°-185°. It doesn't overheat or smell of antifreeze. Now this is how I purged the coolant system after the back flush ect. I put on my no spill funnel cracked the bleeder valve filled until full, closed the bleeder valve and started the car. I let her run for close to an hour while bubbles circulated themselves out the funnel once the bubbles had stopped I made sure the rad. was full and capped her.
    Now I am not an idiot I know that it is obviously going to heat up a bit while idling due to lack of air flow through the radiator but ... my question is ... is this normal do you guys/girls have this issue.. could it be a faulty tstat?
    Pictures of driving @ 65 mph vs idling after drive for 5min-10min
  2. #2 Re: Temps rise when idling 15°-20°
    unless its doing this while driving its fine. mine will hit the 1/2 way mark then the fans come on if left to idle. driving im a tick over the 1/4 line.
  3. #3 Re: Temps rise when idling 15°-20°
    Nov 2013
    Des Moines, IA
    Yeah my fans have yet to ever come on. I don't think they are faulty but its just cold as hell here. is there a way to force the fans on ? just to verify they function ?
  4. #4 Re: Temps rise when idling 15°-20°
    turn the a/c or defroster on, the fans should turn on at any temp.
  5. #5 Re: Temps rise when idling 15°-20°
    oh, this only works if your a/c is in working condition.
  6. #6 Re: Temps rise when idling 15°-20°
    Nov 2013
    Des Moines, IA
    I run my defroster every morning as its 20° outside and there is usually frost makes me wonder if they don't work hmmm. Haven't even tested the a/c haven't needed to <--------- lol but I will definitely do that later
  7. #7 Re: Temps rise when idling 15°-20°
    Nov 2013
    Des Moines, IA
    I take ^ back I did test the a/c and I remember hearing the clutch or whatever "click" on or engage and they air was pretty cold (temp was in the 50's) so hard to tell but I believe it works
  8. #8 Re: Temps rise when idling 15°-20°
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Not my thread but what it mean if it does this while driving? Both my Prix do this
    Sent from my iPhone
    2004 Grand Prix GTP 150,000 " The New Edition "
  9. #9 Re: Temps rise when idling 15°-20°
    Nov 2013
    Des Moines, IA
    Mine^^^ will do it in stop and go traffic but not when I am on the highway or going at a steady rate.... its weird
  10. #10 Re: Temps rise when idling 15°-20°
    Oct 2012
    Philadelphia
    Quote Originally Posted by 2007GPGTSC View Post
    Yea I feel you my cars get freezing if I go on the highway on a cold day, the temp gets to almost 1/4 , I never thought of it as a problem, I just looked at it like it's just the cold air .
    Sent from my iPhone
  11. #11 Re: Temps rise when idling 15°-20°
    Quote Originally Posted by Bills1997GTP View Post
    Sent from my iPhone
    say your driving at a steady pace, highway or main road and your temp rises and falls usually means there's air trapped in the lim and it needs to be bled out via the bleeder valve on the t stat housing.
  12. #12 Re: Temps rise when idling 15°-20°
    Nov 2013
    Des Moines, IA
    ^^same makes sense tho.. all that cold air rushing through the radiator. I just don't understand when idling it shoots up so fast like as in a matter of minutes its just like mehh I am going to heat up lol
  13. #13 Re: Temps rise when idling 15°-20°
    my car will be at full temp if left to idle for 10 to 15 minutes in the cold of winter. i get heat (well warm air) as soon as i see the temp needle move off the bottom of cold on the gauge.
  14. #14 Re: Temps rise when idling 15°-20°
    Nov 2013
    Des Moines, IA
    I will try bleeding again via the tstat housing and see how that goes. thanks for the input ^^
  15. #15 Temps rise when idling 15°-20°
    Aug 2013
    McDonald PA
    That's exactly how mine is. It's perfectly fine
    And I just had a coolant flush and new stat put in
  1. Project Grand Prix- The Rise to RACECAR
    By acidcrashdburnd in forum Track Sessions and Kills
    Last Post: 06-26-2013, 09:19 AM
  2. 300: Rise of an Empire
    By TheNoob23 in forum Off Topic Discussion
    Last Post: 06-13-2013, 05:37 PM
  3. crazy high trans temps or no temps!? pics!
    By blknbstd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-20-2011, 06:07 AM
  4. Rise Against/Bad Religion 2011
    By Poil336 in forum Off Topic Discussion
    Last Post: 02-24-2011, 11:59 PM
  5. Engine runs fine till temp starts to rise...
    By 97gpGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2010, 11:22 AM
