Thread: New code,p0069?
Results 1 to 11 of 11
  1. #1 New code,p0069?
    Florida
    Chats
    Car felt weird when i was leaving work today, like sluggish and idle sounded off. Took it to advance code popped up p0069 manifold absolute pressure;barometric ..... Idk. Do i have a bad MAP sensor? Also still have this continuos p401 code if that matters.
  2. #2 Re: New code,p0069?
    Chats
    83662
    Don't 04+ cars have two map style sensors on the backside of the supercharger??
  3. #3 Re: New code,p0069?
    Florida
    Chats
    Yea i believe so.
  4. #4 Re: New code,p0069?
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Chats
    38
    From what I was reading, P0069 is something most likely to do with MAP sensor, but I'm not an expert. And P0401 is EGR is probably sticking open or something. Happens often and a good cleaning will sometimes fix the issue. But again, not an expert =)
  5. #5 New code,p0069?
    Chats
    78
    Map and then a Baro sensor.
    Check the connections and make sure the wire isn't cut or anything.
    04 Comp G.
  6. #6 Re: New code,p0069?
    Florida
    Chats
    Will check in the am too dark now. But changed egr and still same code so.im thinking its dirty/clogged somewhere. May have to take a trip to.junkyard if MAP is bad though.
  7. #7 Re: New code,p0069?
    Chats
    78
    Or post A wtb I'm sure a few guys will have some spares available
    04 Comp G.
  8. #8 Re: New code,p0069?
    Florida
    Chats
    Well sometimes i like to have parts right away and junkyard is 20min away,beats a few days lol. But if i find nothing then.ill see if anybody has.
  9. #9 Re: New code,p0069?
    Chats
    78
    True! But sometimes Gp don't show up let alone 04s+z
    04 Comp G.
  10. #10 Re: New code,p0069?
    GXP Level Member
    Mar 2015
    Tomball
    Chats
    2843
    I realize this is an old post, but what was the resolution? I have had an issue with this as well. Car becomes sluggish won't go into boost. I've changed both the MAP and Baro sensors with new ones I have 3 extras and have swapped them around. Scanned it and Baro reads 28.5 and map at idle is 18.3.
    Jeff
  11. #11 Re: New code,p0069?
    Jun 2021
    Chats
    Gp's pcm uses the map to check EGR floor on de-accelleration. Make sure your EGR is good and that the tube to the intake manifold is good they like to leak at the ends and because it's so hot the only way I've learned to be able to check them is when the engine is started cold while the tube is cold and right away start dumping water on the tube and if white smoke starts coming out of the exhaust then you know the tube is bad.. I've always use propane or water to find vacuum leaks especially water if you don't have a scan tool and if you do then propane while watching the fuel trims is best way to find a vacuum leak
  1. Code P1629 and Code P1573
    By gmsprincess in forum General Tech Discussion
    Last Post: 03-16-2013, 03:39 PM
  2. bad idle maf code driver 6 line 4 code
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2012, 05:56 PM
  3. '99 Grand Prix GT has code 1810, yet runs great as always, so why the code?
    By McFly1999 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 07:52 AM
  4. p0069, p0172 and p2228
    By benblank in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2010, 06:51 PM
  5. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
