Thread: Fuel prime question, not a normal application.
Results 1 to 5 of 5
Threaded View
  1. #1 Fuel prime question, not a normal application.
    SE Level Member snookwheel's Avatar
    Florida
    Hi folks, I have followed this forum for quote a while to learn all I can about the 3.8 SC engine. But now, in spite of searching with reckless abandon, am stumped. I have a 3.8 SC out of a 2002 Grand Prix, it really has been a maintenance free power plant. It installed in a Brunton Super Stalker, a version of a lotus Super 7.
    I was out for a ride last weekend and the engine cut off, it would crank but not restart. I got the Tow-of-shame home on a flat bed and started poking around. The fuel pump relay had gone bad, but now the car does not prime when I turn on the key. I can jump the relay to make the pump run when starting, after it starts, I can remove the jump and the pump continues to run and all is good. I've checked and do have power running to the 'start/run' wire, just no pump running.
    Putting in a bypass switch to use when starting the car works fine, I shut that switch off after starting and the pump does its thing. Any ideas why I seem to have lost the Start/run circuit? I've checked all the fuses... At a loss.
    Thanks for taking time to read my saga, Scott
  1. Replies: 3
    Last Post: 11-29-2012, 05:06 PM
  2. Below normal fuel pressure- backfiring under throttle
    By Blue00GTcoupe in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-29-2012, 11:19 PM
  3. prime the oil system
    By Toms04compg in forum General Tech Discussion
    Last Post: 07-25-2012, 01:53 PM
  4. Optimus prime!
    By gunsn88 in forum Off Topic Discussion
    Last Post: 02-02-2012, 03:49 PM
  5. Is this normal? Replacing fuel pump in 2003 Grand Prix
    By GrandPrixlbc in forum General Tech Discussion
    Last Post: 08-11-2011, 08:51 AM
