Thread: need help asap! Cars shuts off!
Results 1 to 6 of 6
  1. #1 need help asap! Cars shuts off!
    Sep 2013
    ILLINIOS
    ok well i was driving and my 2000 gtp just died, it will turn on and then die again.. I checked the battery connections and they are good. I also checked the fuel pump resistor by bypassing it and still wont stay on.. Im going to check iac and the maf this morning also. Anything else it could be?
  2. #2 Re: need help asap! Cars shuts off!
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    If you start it and give it gas up to about 2k rpm's for a few minutes and then let off does it stay running or die again?
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  3. #3 Re: need help asap! Cars shuts off!
    Maybe the pumps dead or maybe the crank sensor is at fault.
  4. #4 Re: need help asap! Cars shuts off!
    Dec 2011
    Cortland
    Search for fuel pump resistor bypass
  5. #5 Re: need help asap! Cars shuts off!
    Dec 2011
    Cortland
    Unplug your crank sensor and put a test light or volt meter to it to make sure its working. Also check to see if fuel injectors stay on before it dies. Unplug one connector, it won't hurt it, and have someone put a test light on it to see if it is still getting power even while the car is dying.
  6. #6 Re: need help asap! Cars shuts off!
    Dec 2011
    Cortland
    Also might want to check the thing the coil packs sit on. Forget its name but the clip on it is known to "c" shape and go bad
  1. 02 Starts and then Shuts Off?
    By KitRae in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2013, 12:20 PM
  2. Replies: 21
    Last Post: 08-30-2010, 07:41 PM
  3. just shuts off
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 12:16 AM
  4. Engine shuts down
    By jvee44 in forum General Tech Discussion
    Last Post: 06-23-2009, 01:38 PM
  5. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
