Thread: problem shifting
Results 1 to 6 of 6
  1. #1 problem shifting
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    So I had a problem with my car running lean. Fixed that! Fine now. However, I thought the cat was plugged from the lean issue because the car seemed doggy and when accelerating heavily it would just sound like it was really struggling, but not want to shift. So I bought a ZZP downpipe with high flowing cat and just had it put on. Problem still occured. I popped the hood and revved the car up quick and noticed that the lower coolant hose collapses on itself.
    Is that normal?
    Secondly, I believe my thermostat is stuck or at least partially stuck open because on a normal drive the car won't get hardly higher than 2 notches above 160° so I'm sure I probably need to replace that soon. Could either of these things affect the car and make it not want to shift? I'm doubting that.
    Thirdly, I do have a small oil leak under the valve covers, or whatever they are called. It seems to like to puddle up in spots by the supercharger snout but I check my oil often and it's remained full. Even after almost 3 - 4k miles. I'm also doubtful that will affect shifting.
    Lastly, my dad told me that my uncle had a problem similar sounding to my issue with his Grand Am and unplugged the Mass Airflow Sensor which made his car shift really hard, but shifted non the less. However, made his car idle rough. So I unplugged mine and sure enough, shifts fine, not doggy feeling, no rough idle either. Feels like a monster. Got home after roughly a 15 minute drive and was still running fine. I put it in park and it started to hickup and go from roughly 850 - 1100 RPM and then drop back down to 850 again. Then smooth out and hickup again. So I shut it off. Hopefully Sunday I can get a new Mass Airflow sensor.
    Does anyone think there is more issue than just this?
    Thoughts?
  2. #2 Re: problem shifting
    id try a used maf, as thats the cheap way to go. if it ran better unplugged 99% of the time the maf is bad.
    you can try cleaning it as well, use only maf cleaner to clean it.
    check the wires to the plug for the maf for damage. bad wires can also cause issues.
    and do a t stat as well. not shift related but needs to be addressed. and the valve cover gaskets one of these days.
  3. #3 Re: problem shifting
    Aug 2011
    Michigan
    Would the MAF from an 02 Grand Prix SE work for this car as well?
  4. #4 Re: problem shifting
    what year is your car?
    theres certain years that use the same maf, theres a part number on the top of it, see if its the same.
  5. #5 Re: problem shifting
    Aug 2011
    Michigan
    I own a 1999 GTP and an 02 SE. The SE is dead unfortunately =( I'm not home so I'll have to check tomorrow or Sunday
  6. #6 Re: problem shifting
    it may be the same, check the part #. if its the same it will work.
  1. 4T60E shifting problem
    By wrpfctr7 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 01-21-2014, 08:02 PM
  2. shifting problem
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 11-19-2012, 01:06 PM
  3. 95 GP Shifting problem
    By DaveB in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 10-22-2011, 03:53 PM
  4. Shifting Problem
    By taximech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2010, 07:06 AM
  5. Shifting problem, pls help
    By mtrmes02 in forum General Tech Discussion
    Last Post: 01-23-2010, 09:07 PM
