Thread: in need of vacuum line pics
Results 1 to 20 of 32
  1. #1 in need of vacuum line pics
    Oct 2013
    Indiana
    I have my car back together after my lim gasket change but now it runs super rough. I am pretty sure its my vacuum lines. im looking for detailed pics of vacuum lines where they run what they go to all that fun stuff if you.could help me out that would be great!
  2. #2 Re: in need of vacuum line pics
    Omaha, NE
    Year? Model?
  3. #3 Re: in need of vacuum line pics
    Oct 2013
    Indiana
    sorry 98 gtp engine out.of a Bonneville but I dont think that matters with vacuum lines
  4. #4 Re: in need of vacuum line pics
    Mar 2013
    Colorado - USA
    Let's see a couple of pics detailing the top-side front, back and rear of your engine as it is now.
    E85 L32 S1X Heads 105#Crow Springs LQ4 2k+NStarTB Deka 60# Gen1 SLP Headers Stock Plugs
    19 deg GFS and ZERO KR@14 PSI <10% LTFT
    GMPP Struts/Springs SLP Sway Bars Z06 Brakes
  5. #5 Re: in need of vacuum line pics
  6. #6 Re: in need of vacuum line pics
    this is how it should be set up.
  7. #7 Re: in need of vacuum line pics
    that open port in your first pic is the way its supposed to be, all is good there. its a vent, it used to have a foam filter on it. but they fall off. not a problem.
  8. #8 Re: in need of vacuum line pics
    Oct 2013
    Indiana
    so everything looks ok?
  9. #9 Re: in need of vacuum line pics
    it does. it running ok?
  10. #10 Re: in need of vacuum line pics
    Oct 2013
    Indiana
    no runs super rough white smoke out the back supercharger doesnt get boost and it putters out
  11. #11 Re: in need of vacuum line pics
    out the back of the sc? hows that possible? you sure its not oil leaking and burning off?
    your check engine light on? last known tune up?
  12. #12 Re: in need of vacuum line pics
    ok read the first post, missed it before. just did the lim gaskets. you got the two O rings in place on the lim? or the lim's coolant ports sealed off?
    do you smell coolant burning? see it leaking anywhere? the only way coolant can come out of the gasket area is if the 2 ports are leaking, then force it out the gasket. or the matting surfaces were not cleaned well enough, maybe a chunk of old gasket got left on the lim or sc?
  13. #13 Re: in need of vacuum line pics
    spray some carb cleaner around the engine, and lim and sc. if the idle jumps up you got a vac leak.
    and the fat vac hose off tb, that goes to the evap, is that hose ok ? they crack too and cause a huge vac leak.
  14. #14 Re: in need of vacuum line pics
    Oct 2013
    Indiana
    what it seems like I need to do is take the lim gasket off and redo.it... idk tho im fairly positive its not a vacuum leak but you never know
  15. #15 Re: in need of vacuum line pics
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    everything vacuum wise looks correct. White smoke is not a vacuum leak. Like scotty said, did you install the two yellow o rings behind the egr hole on the LIM with your gasket also? White smoke is usually water burning...
    Hold your hand against your passenger side tip (while the car is running) for a few seconds, pull it away and look... Bet your hand's wet...
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  16. #16 Re: in need of vacuum line pics
    Oct 2013
    Indiana
    yea but what does that mean? I'd I have water coming out and I didn't have any antifreeze in it why would that happen? btw I forgot to mention the car say for maybe 2 months before I started it. and yes I put the o rings in on the egr under the supercharger.
  17. #17 Re: in need of vacuum line pics
    Nov 2009
    Tennessee
    Condensation would go away fairly quickly.. And even though you did drain coolant for the LIM job, you still have water in your block. Once the pump starts circulating water from the block will move around.
    IF you did put your hand back there and your hand is wet then you are blowing water through your motor. When my LIM gaskets blew, I held my hand back there for a few seconds and my hand was pretty wet, not dripping wet but I could shake moisture off my hand. (if that makes sense)
    Back to the condensation issue, it should burn off fairly quick. I do not know how long you let your car run or how many times you have started it since your LIM gasket change, but if you are still blowing water through your exhaust (along with it running badly) and it does not go away I'd be willing to bet something did not seal up right. If you had a non supercharged car I'd point toward the black UIM having a crack, but that's not the case here. I've heard of the orings shifting during install, that's why I plug the holes up on the ones I've done. When I top swapped mine, I plugged the holes as well as used the orings... Others cam comment, but I'm on the same page Scotty is.
  18. #18 Re: in need of vacuum line pics
    Oct 2013
    Indiana
    im pulling it all off again today so ill let you guys know what happened
    building a mustang killer one broken bolt at a time.
  19. #19 Re: in need of vacuum line pics
    Oct 2013
    Indiana
    deff the lim gasket i have water all in the lim
  20. #20 Re: in need of vacuum line pics
    Nov 2009
    Tennessee
    Figure out why?? O rings, bad gaskets, didn't clean well, ??
  1. Vacuum Line
    By sumdude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2011, 03:05 PM
  2. i need a vacuum line
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 04-20-2010, 09:07 PM
  3. vacuum line kit for 98 gtp?
    By Liquifire in forum General Tech Discussion
    Last Post: 11-09-2009, 09:49 AM
  4. Vacuum line
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:11 PM
  5. Vacuum line...where does it go
    By chrizzle17 in forum General Tech Discussion
    Last Post: 02-25-2009, 11:15 PM
