Thread: brakes
Results 1 to 5 of 5
  1. #1 brakes
    SE Level Member ssiebor14's Avatar
    May 2013
    Biglerville
    Like said in the title brakes. My front driver side brakes make a loud grinding whenever I come to a stop. Also. My brake lines a fully rusted. Change or no?
  2. #2 Re: brakes
    Surface rust on the lines isnt a issue really, but if they look super bittle and you think they might snap with some pressure from your hand, then you might want to address it.
    The grinding means your pads are gone and the backing plate is grinding metal on metal with the rotor. So its time to buy some new pads and rotors.
  3. #3 Re: brakes
    May 2013
    Biglerville
    Rotor are completely fine though. I'm changing brake lines because they might pop if I brake to hard which is bad I'm changing brake pads after that's done
    Sent from my HTCONE using Tapatalk
  4. #4 Re: brakes
    I wouldnt pad slap rotors, and you best be sure the inside of the rotor is still fine. You might not see where the issue is.
    Take the rotors to get turned if they have enough meat on them or just buy new rotors.
  5. #5 Re: brakes
    May 2013
    Biglerville
    Buying new rotors brakes lines are replaced
  1. Brembo brakes or f-body brakes? Any other choices?
    By LAST2DOOR in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2013, 10:37 PM
  2. Anyone ever use these brakes?
    By JoeNest in forum Introductions/Noob Questions
    Last Post: 06-24-2013, 12:00 PM
  3. 04 brakes
    By anarchy in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2012, 07:31 PM
  4. Brakes squealing even after foot is off brakes
    By GTLGDP in forum General Tech Discussion
    Last Post: 06-26-2012, 09:16 PM
