Thread: Bad startup when cold....
Results 1 to 13 of 13
  1. #1 Bad startup when cold....
    SE Level Member sco77's Avatar
    MD
    Ever since I got my engine together and running I can't figure out what is causing cold starts to be so bad, on cold start (under 100-120F coolant I would say) it will lope between 2000 and 500 rpm, sometimes even stall now that it's cold out.. It will do this for about 30 seconds, unless you touch the gas then it will correct itself faster. EVERY sensor is new, and I even tried swapping in another MAF and IAC. Got a completely different computer tune and it didn't change at all. There is ABSOLUTELY no vacuum leaks, unless its at the LIM (I don't see how).
    Maybe unrelated but it also vibrates very rough around 1500rpm. Looking at scans I see no misfiring or any sensor values out of the ordinary. Could a dying battery cause this? I do know one of the cells in the battery is failed/failing (no starting problems but low 11.x voltage).
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  2. #2 Re: Bad startup when cold....
    whats it charging at? if it cranks then fires up then the battery shows over 12 volts it should run ok.
    kinda sounds like a vac leak, try carb cleaner sprayed at the vac lines and base of the blower trick yet?
  3. #3 Re: Bad startup when cold....
    Any mods?
  4. #4 Re: Bad startup when cold....
    MD
    Any mods?
    VS cam, injectors, N*
    98 GTP - Retired
  5. #5 Re: Bad startup when cold....
    Did you do a case learn after the cam install? Cams make the car harder to start
  6. #6 Re: Bad startup when cold....
    Sep 2013
    NC
    Tried crank shaft position sensor?
  7. #7 Re: Bad startup when cold....
    Most times after a cam, you'll get that surging start up. DH has mentioned bumping timing in the idle to smooth it out.
  8. #8 Re: Bad startup when cold....
    GT Level Member mguzzo's Avatar
    Buffalo NY
    i have the same mods and the same issue. Cold start sometimes will lope a little bit, I think that it's the N* IAC valve trying to maintain a good AFR during the start phase. You can try to take it out and clean it and see if it helps response. I think the N* acts just a little bit richer on startup.
    I know in the PCM there is a IAC step value, I don't know what the optimum value should be for the N* versus a stock throttle body.
    Another option is to drill a small (1/16" - 3/32") hole in the TB plate to let just a little bit more air.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  9. #9 Re: Bad startup when cold....
    I have been trying to figure this out for a year... good luck fellas
  10. #10 Re: Bad startup when cold....
    I'm telling you guys..it's been figured out.
  11. #11 Re: Bad startup when cold....
    MD
    So you think it's most likely the TB/IAC related?
    98 GTP - Retired
  12. #12 Re: Bad startup when cold....
    Quote Originally Posted by sco77 View Post
    Not at all. I suggested asking another member about how he tunes for this issue.
  13. #13 Re: Bad startup when cold....
    I could never figure it out no matter what I tried via tune or anything so I just said to hell with it and have gotten used to it...
  1. cold weather brings cold engine
    By Garrett Mofford in forum Engine
    Last Post: 12-31-2012, 08:45 PM
  2. RE: Stalling @ startup (cold only)
    By pbxcomm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-30-2012, 07:54 PM
  3. Rough Cold Startup
    By mlasnoski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2010, 03:41 PM
  4. Trans is dead on cold startup
    By brand121 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-21-2010, 03:45 PM
  5. Surging on cold startup / down on power
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 11-15-2010, 03:07 AM
