Thread: no injector pulse?
Results 1 to 18 of 18
  1. #1 no injector pulse?
    Aug 2013
    Kitimat, B.C.
    All I did was disconnect the battery and took off plug wires to remove the tunkside exhaust to weld up a leaking header and weld a wideband bung in the down pipe. I also replaced the map sensor. With a new one. It cranks and I have fuel pressure. I also checked and verified spark on two random wires. I also noticed that while cranking the temp guage peggs which it never has before. I have fuel pressure but no wet fuel on plugs. I hooked up hptuners and scanned as I cranked it over and nothing reading on the injector duty or either injb1 or injb2. Looks like the injectors ain't firing.
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: no injector pulse?
    Swap the other map back into it and see what happens
  3. #3 Re: no injector pulse?
    Aug 2013
    Kitimat, B.C.
    The other map is nfg, I broke the vacuum port before nd I glued it to get by till I got the new one.
  4. #4 Re: no injector pulse?
    SE Level Member Monday's Avatar
    May 2012
    Danielleland
    You won't pulse when cranking. You only pulse before cranking when the pump primes. Then once it starts injectors resume.
  5. #5 Re: no injector pulse?
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by Monday View Post
    Ok wrong choice of words then, basically I'm getting no fuel from the injectors. I have power to both injector wires.
  6. #6 Re: no injector pulse?
    Try starting with starting fluid?
  7. #7 Re: no injector pulse?
    Yeah.. I thought you meant not injector pulsing to give you fuel. The way it works is the pcm on key on, primes the fuel pump and pulse the injectors quick to prime the cylinder for start up. Injectors are then not pulsed again until start up or a little throttle.
    The ignition supplies voltage to the injectors and they stay hot as long as the ignition is on. The pcm grounds the injector as it sees fit.
  8. #8 Re: no injector pulse?
    Aug 2013
    Kitimat, B.C.
    Yeah my injectors ain't giving me fuel. I will have to re check but I think there was voltage to both wires even while cranking.
  9. #9 Re: no injector pulse?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    do what dsmuts said and try using a little starting fluid. this will verify a fuel issue
    I went NA when a whore left -$300 in my bank account.
  10. #10 Re: no injector pulse?
    Aug 2013
    Kitimat, B.C.
    Welli found the problem, it's the new map sensor, I unplugged the new one and plugged it into the old one but left the vacuum line connected to the new one. It took a few cranks but it fired up. I left it running and plugged it back into the new sensor and it stayed the same. If I shut it off and restart it in the new, it won't start. This is the sensor I bought.
    http://www.ebay.com/itm/231...id=p3984.m1439.l2649
    Andy suggestions as to why the new one don't work?
  11. #11 Re: no injector pulse?
    hmm who could have called that? lol
  12. #12 Re: no injector pulse?
    Aug 2013
    Kitimat, B.C.
    Yess sir but you only get a cookie as you only got a half answer. You never explained why. Lol
  13. #13 Re: no injector pulse?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    hook up a vacuum pump to the map and watch what it does on a scanner, probly a bum sensor.
    On standard's website they list the as4 for vin 1,
    ship it back on warranty?
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  14. #14 Re: no injector pulse?
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by Seachicken View Post
    I'm not sure if I'm a vin 1 as I have a donor motor in the fiero. For the vacuum thingy, does the vehicle have to be running or just KOEO? I've contacted the seller, waiting a response. I have put in a 2 bar that I had ordered for another project but though it was wrong as the idle was surging, turns out I didn't let it learn. Now that same sensor idles fine. What should the map numbers be with the engine running?
  15. #15 Re: no injector pulse?
    Vin 1 is supercharged.
  16. #16 Re: no injector pulse?
    Aug 2013
    Kitimat, B.C.
    So I take it I did get the correct sensor?
  17. #17 Re: no injector pulse?
    Half a cookie is better than no cookie
  18. #18 Re: no injector pulse?
    Aug 2013
    Kitimat, B.C.
    The company is sending a replacement, so we'el see.
  1. headlights flicker and pulse.
    By 97gpl36 in forum General Tech Discussion
    Last Post: 07-01-2013, 05:29 PM
  2. Light pulse when amp hits
    By BeastGT in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2011, 11:58 AM
  3. How-to add LED's & have them pulse from amplifier
    By mousemonster1232 in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2011, 06:46 PM
  4. need help asap no injector pulse 5th cyl
    By jenkins6586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 06:47 PM
  5. Pulstar pulse plugs?
    By a98gtp4u in forum General Tech Discussion
    Last Post: 09-20-2009, 08:47 PM
