Thread: Can anyone recommend a good aftermarket Fuel PSI regulator for me? (2005 GP)
Results 1 to 11 of 11
  1. #1 Can anyone recommend a good aftermarket Fuel PSI regulator for me? (2005 GP)
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Just doing some research in case I need a new one with the Aeromotive 355 I installed last week. I seem to have trouble starting my car now.
    Can I bypass the in tank and run an external?
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Can anyone recommend a good aftermarket Fuel PSI regulator for me? (2005 GP)
    Feb 2009
    flintnasty MI
    I would suggest running a stock L67/L36 regulator myself.
    Also, the regulator is in the fuel filter on 04+ right?
  3. #3 Re: Can anyone recommend a good aftermarket Fuel PSI regulator for me? (2005 GP)
    Apr 2012
    Middletown DE
    its in the canister, no real filter just a sock.
    1993 Oldmobile 88
  4. #4 Re: Can anyone recommend a good aftermarket Fuel PSI regulator for me? (2005 GP)
    Feb 2009
    flintnasty MI
    IDK man, looks pretty regulator to me.
  5. #5 Re: Can anyone recommend a good aftermarket Fuel PSI regulator for me? (2005 GP)
    Apr 2012
    Middletown DE
    and no in-line filter
    1993 Oldmobile 88
  6. #6 Re: Can anyone recommend a good aftermarket Fuel PSI regulator for me? (2005 GP)
    Ohio
    Like Scott said, the regulator is in the canister lol
  7. #7 Re: Can anyone recommend a good aftermarket Fuel PSI regulator for me? (2005 GP)
    Feb 2009
    flintnasty MI
    How hard is it going to be to get the return line setup on the top of the sending unit? Also going to need to bypass the "in tank filter regulator" thing there.
  8. #8 Re: Can anyone recommend a good aftermarket Fuel PSI regulator for me? (2005 GP)
    Apr 2012
    Middletown DE
    Well I am 100% set on going to a return system. I have to figure out if the 97-03 canister will fit on/in my tank rather than bypass anything I want to do it right. As of now I am going from a 3.0 to a 3.3 pulley until next spring.
    1993 Oldmobile 88
  9. #9 Re: Can anyone recommend a good aftermarket Fuel PSI regulator for me? (2005 GP)
    Feb 2009
    flintnasty MI
    The advantages of a "return" system are minimal at best. I would rather just upgrade the fuel pump to handle what you need at this point. You can make more than enough power on a big single pump.
  10. #10 Re: Can anyone recommend a good aftermarket Fuel PSI regulator for me? (2005 GP)
    Apr 2012
    Middletown DE
    I had 2 big pumps, Walbro 255 and an Aeromotive 355
    both made my car run like ****, hard as **** to start and it would lean out at WOT 13.5-14 while the stock pump was 10.5-11.3.
    I am bypassing the **** stock regulator and converting to the return style system so I can adjust the pressure.
    Also doing a check valve or a manual switch to power on the pump on to resolve the hard starting.
    1993 Oldmobile 88
  11. #11 Re: Can anyone recommend a good aftermarket Fuel PSI regulator for me? (2005 GP)
    Feb 2009
    flintnasty MI
    Install error should not be an excuse as to why it didnt work. Put them in right and you wont have any problems. If you have pressure creep a 15dollar switch can turn the second pump off out of boost.
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. Fuel regulator
    By Dee23 in forum Engine
    Last Post: 09-30-2012, 12:03 AM
  3. Cap off fuel regulator?
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2011, 06:09 AM
  4. Recommend a good brake pad.
    By Z28 in forum Brakes/Suspension/Chassis
    Last Post: 11-21-2008, 02:50 PM
