Thread: 105# Springs or 130# for a XP Hot Cam?
Results 1 to 20 of 35
  1. #1 105# Springs or 130# for a XP Hot Cam?
    Banned
    Jan 2013
    maryland
    XP camming the motor this month buying Springs today want to know which Springs you guys prefer 105 or 130? Can I run a stock chain with either? And can I run stock pushrods? Thanks!
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  2. #2 Re: 105# Springs or 130# for a XP Hot Cam?
    Ohio
    105 springs, stock replacement chain and stock pushrods.
  3. #3 Re: 105# Springs or 130# for a XP Hot Cam?
    Banned
    Jan 2013
    maryland
    Cool thank you sir
    GTX Level Member crbquist's Avatar
    Massachusetts
    Many say to go 130's to take full advantage of the xp's upper rpm power. But, either or would work. A stock chain will be fine for a good while, but eventually would need to be replaced along with the dampener.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  5. #5 Re: 105# Springs or 130# for a XP Hot Cam?
    Banned
    Jan 2013
    maryland
    Could I use 130# springs with a stock chain?
  6. #6 Re: 105# Springs or 130# for a XP Hot Cam?
    Massachusetts
    Quote Originally Posted by jayroca View Post
    You could, but there is no guarantee as to how long it will last. Guys typically go with a double roller for 130's. I run the s1x cam with 105's and a stock chain. 10k miles later and so far so good..
  7. #7 Re: 105# Springs or 130# for a XP Hot Cam?
    Jan 2013
    Australia
    130lbs springs for XP hot is complete overkill... its not a big cam
  8. #8 Re: 105# Springs or 130# for a XP Hot Cam?
    Banned
    CT
    Quote Originally Posted by Schwuppes View Post
    Not really, that depends on more variables than just the cam.
    The XP needs 105s at a minimum. I think the reason most people get away with them is because install height in our cars is usually 1.78 with the retainers we use, not the rated 1.8. That makes the seat pressure a little higher.
    To really handle the XP though, 130s are more desirable... especially on higher horsepower builds.
    I used to think it didn't really matter... until I saw dyno graphs from various (and my own) setups, showing the 130s helped carry the power a little higher.
  9. #9 Re: 105# Springs or 130# for a XP Hot Cam?
    Massachusetts
    Quote Originally Posted by SnowFlake View Post
    ^^^^this^^^^
  10. #10 Re: 105# Springs or 130# for a XP Hot Cam?
    Banned
    Jan 2013
    maryland
    So 130# springs with a double roller?
  11. #11 Re: 105# Springs or 130# for a XP Hot Cam?
    Massachusetts
    105's will suffice unless you plan on shifting at super high rpms. You may want to consider the s1x cam as well.. Almost the same size as the xp and would probably be more specific to 105 springs due to the better mid-range power.
  12. #12 Re: 105# Springs or 130# for a XP Hot Cam?
    Banned
    CT
    Quote Originally Posted by crbquist View Post
    Easy there... this whole notion that the s1x has better mid-range is a fallacy.
    If anything, the XP cam has a wider power band due to the s1x having a tighter LSA.
  13. #13 Re: 105# Springs or 130# for a XP Hot Cam?
    Massachusetts
    Regardless, I doubt anyone would notice any big difference between the two. I went with the s1x because intense was having a sale at the time, so it was $50 cheaper than the xp. Can't wait to see how this cam works with E85
  14. #14 Re: 105# Springs or 130# for a XP Hot Cam?
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    If I were you do the double roller now. Wether you use the 105s or 130s better to be safe. But get a double roller timing chain installed.
    If You Cant Hear The Whine You're Too Far Behind...
  15. #15 Re: 105# Springs or 130# for a XP Hot Cam?
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by GTP89 View Post
    Yeah I feel a lot a members on the forum run single chains with no problem but I'll be safe then sorry.. I've heard that i have to machine the oil pump cover along with using 2 front cover gaskets iirc would I or could I just "install" one?
  16. #16 Re: 105# Springs or 130# for a XP Hot Cam?
    Banned
    CT
    Yeah you're right... the difference is so small that there's pretty much no way anyone would be able to decipher between the two.
  17. #17 Re: 105# Springs or 130# for a XP Hot Cam?
    Banned
    CT
    Machine the gear and the cover, run 1 gasket.
  18. #18 Re: 105# Springs or 130# for a XP Hot Cam?
    Banned
    Jan 2013
    maryland
    Thanks would you guys use the cam install kit from zzp or just piece your parts from rockauto?
  19. #19 Re: 105# Springs or 130# for a XP Hot Cam?
    Massachusetts
    Rock auto for sure.. That's what I did.
  20. #20 Re: 105# Springs or 130# for a XP Hot Cam?
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    do a double roller. you never know where your build will end up. I just snapped my single roller on my xp cam twincharge
  1. #90 springs or #105?
    By jman44 in forum Introductions/Noob Questions
    Last Post: 07-09-2013, 08:48 PM
  2. Replies: 39
    Last Post: 02-04-2013, 10:42 AM
  3. new springs maybe?
    By Freddy in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2012, 11:09 PM
