Thread: SD headers - can a new flex be welded on without removing rear header?
Results 1 to 9 of 9
  1. #1 SD headers - can a new flex be welded on without removing rear header?
    Cambridge, Ontario Canada
    Looks pretty tight up there
    2005 E55 - stock
  2. #2 Re: SD headers - can a new flex be welded on without removing rear header?
    Likely not with it bolted to the head.
  3. #3 Re: SD headers - can a new flex be welded on without removing rear header?
    gardner,mass
    Sure it can.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  4. #4 Re: SD headers - can a new flex be welded on without removing rear header?
    It can but I wouldn't expect the welds to be great and it to be leak free. There's not much room for you to weld the top of the flex. Take a hour out of your day and remove it.
    04 Comp G.
  5. #5 Re: SD headers - can a new flex be welded on without removing rear header?
    Antioch, IL
    Cut my flex off and welded in 3" 45°. Didnt unbolt nothing or have problems getting it welded back on
    2009 Challenger SRT8
    Expert at being gay.
  6. #6 Re: SD headers - can a new flex be welded on without removing rear header?
    Quote Originally Posted by ITHURTZ View Post
    Pics?
    04 Comp G.
  7. #7 Re: SD headers - can a new flex be welded on without removing rear header?
    Antioch, IL
    its raining right now, ill see if I can remember tmw.
  8. #8 Re: SD headers - can a new flex be welded on without removing rear header?
    No problem I'm curious because I plan on pulling my header in the next few days and modifying it
    04 Comp G.
  9. #9 Re: SD headers - can a new flex be welded on without removing rear header?
    Antioch, IL
    here red almost forgot so just took them. dont mind the no exhaust I cut it off a few days ago.
    Uploaded with ImageShack.us
    Have to be careful where you cut, the pipe merge isnt very far from the flex pipe. But there is plenty of room to get a mig in there.
  1. SD Headers - what size ZZP flex? 99 GTP
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2013, 12:21 PM
  2. So I was looking at my flex pipe on my SSAC Headers and...
    By acidcrashdburnd in forum General Grand Prix Discussion
    Last Post: 05-05-2013, 09:02 PM
  3. SLP header flex section ticking
    By copterdoctor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2008, 10:29 AM
