How can I tell if I need a magnasteer or not can I get a rack n pinion cheap?
If it is magnasteer you'll have a wiring harness coming off the rack
IIRC everything 98+ GT and GTP had magnasteer, SE's were w/o magnasteer. Only 97 had magnasteer as an option... But I could be wrong...
But yes, if it's a magnasteer unit there's a two pin plug coming off your rack below where the steering shaft attaches.
You dont have to run the mag steer tho
Ebay from detroitaxle. I got mine with Magnasteer for $104. Works great.
No point in not running mag steer if you have the option. Mag steer is only a few bucks higher.
Ok another incident i took the cap of radiator and water got on belt. belt slip of and broke the metal that the belt tensioner is on off the motor. Is this fixable? I want this car
Would kinda like to wire up the mag steer in my 97 monte but i havent figured out where to wire it to i know one goes to vss but wut about the other one? Sorry to thread jack![]()
