Thread: 2006 Grand Prix GT: What pulley is this? (Video)
Results 1 to 13 of 13
  1. #1 2006 Grand Prix GT: What pulley is this? (Video)
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    My car has been making an awful grinding noise at around 2K RPM. I think I may have found the problem, whatever pulley this is, is slipping, I'm pretty sure its the A/C compressor(the one at the bottom). I dont have a belt diagram or a owners manual to confirm. Thanks ahead of time, heres the video, skip to around :20 seconds to get a better view:
    Do you think this would make a grinding sound?
  2. #2 Re: 2006 Grand Prix GT: What pulley is this? (Video)
    The one at the very very bottom that hardly seems to spin at all is the AC compressor's clutch/pulley.
    The clutch looks like its slowly rotating with the pulley but at like a 1 turn per every few thousand of the a/c's pulley itself.
    Try engaging the ac compressor and see if the noise stops.
  3. #3 Re: 2006 Grand Prix GT: What pulley is this? (Video)
    May 2011
    I have engaged the compressor and it definately seems to quiet down. But it still can be heard sometimes, maybe when it slips?
    Is the clutch supposed to slowly rotate like that?
  4. #4 Re: 2006 Grand Prix GT: What pulley is this? (Video)
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Look like a/c compressor clutch is starting to go
  5. #5 Re: 2006 Grand Prix GT: What pulley is this? (Video)
    Portland Oregon
    Either the clutch is going or the compressor is frozen. No pun intended B-)
  6. #6 Re: 2006 Grand Prix GT: What pulley is this? (Video)
    May 2011
    When I engage the a/c, the clutch engages and spins fine as far as I can see. I dont think its frozen as the a/c still works.
    I can still hear the sound with the a/c on sometimes, not as much though and not as loud.
  7. #7 Re: 2006 Grand Prix GT: What pulley is this? (Video)
    May 2011
    Next Question: How do I fix it?
  8. #8 Re: 2006 Grand Prix GT: What pulley is this? (Video)
    Either replace the ac compressor clutch, from what I have read its a real huge pain to replace, or get a new compressor, iirc they are ~$170 from Rockauto, or you could try a used one from a junkyard.
  9. #9 Re: 2006 Grand Prix GT: What pulley is this? (Video)
    you need a new compressor, you can see the center of the clutch turning little by little in the vid you posted.
    you can try spraying wd 40 or some spray grease in the clutch under the pulley area there little holes you can spray into.
  10. #10 Re: 2006 Grand Prix GT: What pulley is this? (Video)
    May 2011
    Thanks, I'll give the wd40 a go, hopefully it quiets it down.
  11. #11 Re: 2006 Grand Prix GT: What pulley is this? (Video)
    its by no means a permanent fix, but if the sound goes away you know for sure its the compressor.
  12. #12 Re: 2006 Grand Prix GT: What pulley is this? (Video)
    May 2011
    Yea, the sound went away. I'm happy for now. I guess I'll have to be on the lookout for a new compressor.
  13. #13 Re: 2006 Grand Prix GT: What pulley is this? (Video)
    When mom and dad's van started doing this I had to replace the ac compressor about 2 months later because it locked up. Dad replaced the battery thinking it was bad but I took the belt off and the van started up fine. New compressor and all is well.
  1. 2006 Grand Prix GXP
    By cjulianfly in forum For Sale - Vehicles
    Last Post: 09-02-2013, 10:45 PM
  2. 2006 Grand Prix
    By chad mick in forum Introductions/Noob Questions
    Last Post: 11-25-2012, 04:34 PM
  3. My 2006 Grand Prix HID headlights review - video and pics
    By daiadvisor in forum Visual/Body Modifications
    Last Post: 12-04-2011, 11:34 AM
  4. 2006 Grand Prix Help Please!
    By Shake_Zula in forum Tires & Wheels
    Last Post: 05-08-2009, 10:45 AM
