Thread: pcm questions?
Results 1 to 9 of 9
  1. #1 pcm questions?
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    hey you guys was just wondering, Lets say I buy some ones zzp pcm off them. Do I need to have it programmed to my vin numbers?
    Or can I just put plug it in and go?
    Because people have told me ya just plug it in it will work and others have said dont **** with it its gotta be programmed to your vin
    99 Silver Gtp here --------------------> http://www.grandprixforums.net/my-99...gtp-80323.html
    slp headers ,straight pipe, intriuge suspension, cai, ported tb, performance roller lifters, and bulit trans. 04+ seats in and le spoiler on
  2. #2 Re: pcm questions?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    A pcm or powertrain control module is basically a computer that controls all the setting in your engine and trans. It depends on how the pcm is programmed if it will work in your car. I did give my vin number whenever I got a pcm tuned but I don't know if that is necessary or not.... Whenever I got a mail in tune I told intense all the mods I had on my engine and trans and they adjusted the setting to match my mods. For instance if the pcm you get is set for higher shift points and your motor is stock you will get valve float at high rpm. As far as the vin number thing idk
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  3. #3 Re: pcm questions?
    Jan 2013
    west palm
    Quote Originally Posted by tms8582 View Post
    oh I know that im not a noob, but was just curious about my vin. would not haveing my vin programmed in be a problem?
  4. #4 Re: pcm questions?
    Washington Michigan
    I honestly don't know bro.... I know Intense asked for my vin number but that might just be for the appropriate settings for that the model, year etc. In other words a 97 gtp might have slightly different settings and parts than a 2002.
  5. #5 Re: pcm questions?
    Jan 2013
    west palm
    good point bro
  6. #6 Re: pcm questions?
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    As far as I am concerned it doesn't matter, usually as far as I know it's to make sure the PCM reads the same vin as the car for smog and such. I have switched a couple of PCM around and work fine without issues. Just make sure it works with the year you need. Like 98-02 I believe is the same gt or Gtp 97 and 03 are different.
    If You Cant Hear The Whine You're Too Far Behind...
  7. #7 Re: pcm questions?
    Jan 2013
    west palm
    Quote Originally Posted by GTP89 View Post
    Thanks, now i wish i took that pcm off that 01 dammit it had headers pulley. dddddddddddaaaaaaaaaaam
  8. #8 Re: pcm questions?
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Quote Originally Posted by titanfan12 View Post
    Doesn't mean it was tuned. Most likely it was. But ya never know. Although an extra pcm never hurts anyway. Did the car have a modular pulley?
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  9. #9 Re: pcm questions?
    IIRC they did it for warranty reasons... Because, if the vin numbers were different it voided the warranty. Dont know if that is still true or not but thats what I remember way back when they did mine (literally ~6 years ago).
  1. a few questions
    By illy in forum General Tech Discussion
    Last Post: 07-03-2013, 02:38 AM
  2. Window Tint Questions and Rear Speaker Questions
    By Wisconnie in forum General Grand Prix Discussion
    Last Post: 06-22-2013, 07:17 PM
  3. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  4. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  5. E85 questions
    By ls6velless454 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2010, 08:17 AM
