Thread: how much hp will a 72mm tb support?
Results 1 to 17 of 17
  1. #1 how much hp will a 72mm tb support?
    Kemmerer, Wyoming
    how much horsepower will the zzp high velocity throttle body support. I'm trying to decide if I can keep it or upgrade to the N*. I'm going to be using it with my Fwi, Gen V, 1.9 roller rockers, SD headers mated to the stock cat back. in the distant future im planning on porting my heads and installing an intercooler.
    I think at best im estimating 300 whp after the build is done. and I already have the high velocity throttle body. so im trying to decide if the tb will support 300 whp or if I have to run the N*.
  2. #2 Re: how much hp will a 72mm tb support?
    antioch ill
    i dont think you will get 300whp out of that. add a ic and a cam then you will be at 300 if not a little more
  3. #3 Re: how much hp will a 72mm tb support?
    Banned
    CT
    Quote Originally Posted by johntremell View Post
    It'll be fine for what you're doing.
    But your setup will be lucky to see ~240whp with the proper pulley and tune.
  4. #4 Re: how much hp will a 72mm tb support?
    Florida
    Guy i know makes 280whp rockered non ic. Knew another guy.made 286whp and even a few guys make 250ish whp on stock valvetrain all on gen v, just sayin.
  5. #5 Re: how much hp will a 72mm tb support?
    Banned
    CT
    I gotta run my car on that dyno lol
  6. #6 Re: how much hp will a 72mm tb support?
    Kemmerer, Wyoming
    I do have an intercooler planned, as well as ported heads
  7. #7 Re: how much hp will a 72mm tb support?
    Stick with the stock TB untill you out flow it.
    Or if you already have the ZZP TB, stay with that untill you are outflowing it.
  8. #8 Re: how much hp will a 72mm tb support?
    Florida
    Quote Originally Posted by SnowFlake View Post
    Ehh go for it brotha lol.
  9. #9 Re: how much hp will a 72mm tb support?
    Kemmerer, Wyoming
    I have the 72mm high velocity tb now. what indications will there be when im outflowing?
  10. #10 Re: how much hp will a 72mm tb support?
    The MAF will be maxxed out for air flow.
  11. #11 Re: how much hp will a 72mm tb support?
    Feb 2009
    flintnasty MI
    Stock throttle bodies are probably good for unlimited power. Maf is a completely different game all together.. if you outflow a stock maf you can upgrade to a LT1/LS1 maf.
  12. #12 Re: how much hp will a 72mm tb support?
    Kemmerer, Wyoming
    is there an article about upgrading to a different Maf. i've heard the maf is the weak link a few times but I haven't been able to find any info on changing it out. I know at a minimum you have to update the maf tables for the pcm but thats all i've been able to find. chances are i'm overcomplicating it.
  13. #13 Re: how much hp will a 72mm tb support?
    Check vacuum at the vacuum tree during wot. Measure in inches of H2O. Probably worthwhile to check the rest of your intake.
    Drops of around 1-3 " are fine, anything around 10-20" should be "upgraded". What sort of actual gains will you see? Not much. Better off buying an intercooler or a cam.
    If you had an intercooler you might be closer to 300 WHP, but without one, you'll fall very short of that goal.
  14. #14 Re: how much hp will a 72mm tb support?
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    ^Agreed.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  15. #15 Re: how much hp will a 72mm tb support?
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Quick question, since im upgrading to a Gen5 in a few weeks would it just be more beneficial to just upgrade to the N* and LQ4 MAF opposed to keeping my 72mm velocity TB on my Gen5? Beings though the Gen5 inlet is 75mm and the N* is 75mm they're more of a match from the get go and there won't be air restriction or problems with air flow. I have pretty much the same question the thread starter has, and I think knowing which is more beneficial would help us most
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  16. #16 Re: how much hp will a 72mm tb support?
    Kemmerer, Wyoming
    The N* will only make like 5 more HP with this set up
  17. #17 Re: how much hp will a 72mm tb support?
    Jul 2012
    North Philly
    Ported heads and a Camshaft would get you much more power with the N*, the N* would be much more efficient with the airflow. I knew this much, I was hoping someone had dyno/horsepower numbers to show the real gain between the two. If you port your blower inlet to 75mm then I would go with the N*
  1. Motor support?
    By vertebrate in forum General Tech Discussion
    Last Post: 08-20-2012, 01:03 AM
  2. Core Support
    By boothe in forum General Tech Discussion
    Last Post: 03-29-2012, 05:17 PM
  3. lumbar support
    By vincegpking in forum General Tech Discussion
    Last Post: 04-07-2011, 06:44 AM
  4. Needs some GPF support and votes!
    By Swash in forum Off Topic Discussion
    Last Post: 10-07-2010, 02:58 PM
  5. 2-support Mirrors
    By arc in forum 04+ Specifics
    Last Post: 02-08-2010, 02:42 PM
