Thread: 2000 GTP Running Rich
Results 1 to 7 of 7
  1. #1 2000 GTP Running Rich
    Aug 2012
    michigan
    I have a P0172 code and the car runs really rich.
    The following has been tested and I believe is not the problem.
    MAF sensor - replaced
    FPR - replaced
    Plugs/wires - replaced
    Throttle body - cleaned
    Tstat - replaced
    Injector o-rings - replaced
    Other tests that have come back clean:
    O2 sensors operating properly
    Checked back-pressure for clogged cat
    Fuel Pressure okay
    Injectors seem to be injecting more fuel than what seems normal. Is this just due to the fact that it is supercharged? Or could that be the problem. The reliable mechanic that did the test for me said he is not 100% sure if this is just because of the supercharger so I thought I would ask you guys. He said it was slightly more than normal and seemed a bit inconsistent.
    Any other possibilities would be greatly appreciated!!!
    Other symptoms:
    Worse when it is hot. Upon hot restart the rpms surge really bad.
    Seems like when you are coasting (like down a long hill) the rpms surge especially when you hit bumps and once in a while the car will die all together.
  2. #2 Re: 2000 GTP Running Rich
    HUDSON
    Check your ECT (engine coolant temperature sensor), and make sure that it is giving accurate information to the ECM/PCM. If this is malfunctioning, it will make the engine run richer than normal, or leaner than normal depending on the malfunction of the sensor.
  3. #3 Re: 2000 GTP Running Rich
    Aug 2012
    michigan
    The scanner showed a good reading from the ECT as far as I could tell. It slowly warmed up as the car warmed up, and eventually leveled out between 88-90 degrees. Is this number normal? Anything else I should check? Any other advice would be great! Thanks!!
  4. #4 Re: 2000 GTP Running Rich
    SE Level Member Ryan99639's Avatar
    Feb 2013
    Rockford
    mine is literally doing the same thing, my mechanic told me i need new injectors. so im gonna grab some 42.5s and see what happens lol
    BOOSTIN
  5. #5 Re: 2000 GTP Running Rich
    Aug 2012
    michigan
    Okay let me know what happens because I have thrown too many parts at this thing. Thanks!!
  6. #6 Re: 2000 GTP Running Rich
    I'd like to see the live data on the scanner for what the injectors are doing, like how fast they are working. And for other parameters aswell.
    Being supercharged wouldnt have anything to do with it, the car is still going to act like any other 3800 while just under normal throttle.
    Have you tried just for giggles unplugging the MAF and seeing if it ran better when it acts up?
  7. #7 Re: 2000 GTP Running Rich
    Aug 2012
    michigan
    I think at some point during all of this I have, but I'm willing to try anything again to figure this out. I'll let you know how it goes.
  1. Running too rich?
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2013, 09:43 AM
  2. Running rich at times then lean?
    By MustangKiller92 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-23-2013, 11:16 AM
  3. Car is running rich... I think
    By ElAlacran2010 in forum General Tech Discussion
    Last Post: 02-25-2011, 08:51 AM
  4. Running rich
    By saleenprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2010, 08:53 AM
  5. car running really rich
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 04:48 PM
