Thread: platnium spitfire spark plugs
Results 1 to 14 of 14
  1. #1 platnium spitfire spark plugs
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    are these plugs good to use on a 3.4 pulley? ive ran these ever since i got the car. Just curious if these are the right kind for the job. i cant find the heat range for them online so i wanted some other peoples opinons
    99 Silver Gtp here --------------------> http://www.grandprixforums.net/my-99...gtp-80323.html
    slp headers ,straight pipe, intriuge suspension, cai, ported tb, performance roller lifters, and bulit trans. 04+ seats in and le spoiler on
  2. #2 Re: platnium spitfire spark plugs
    Jan 2009
    Tallahassee, FL
    Everyone pretty much sticks to copper core plugs. Autolites are real popular and have good heat range choices.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: platnium spitfire spark plugs
    I'd never run platinum plugs...
    Autolites are cheap and proven to work.
    Are these what you're talking about? http://www.splitfire.com/
  4. #4 Re: platnium spitfire spark plugs
    Jan 2013
    west palm
    Quote Originally Posted by blueguy View Post
    Are these what you're talking about? SplitFire Spark Plugs - Platinum and Copper Classic
    yes that is exactly what im talking about
  5. #5 Re: platnium spitfire spark plugs
    Dude throw those plugs in the garbage
  6. #6 Re: platnium spitfire spark plugs
    St. Louis
    4) Spark Plugs - Change out those stock spark plugs with new ones to restore any lost power. Brands that most tend to go with are either Copper Core Autolites or NGK's. They range as follows in order from hottest to coldest plugs...remember...you want the hottest spark you can get away with...so running a super cold plug on a larger pulley to combat knock isn't the best plan...OEM replacement ACDelco's, AL606's, and AL605's are basically for stock cars or very small bolt-ons still running the stock S/C Pulley or modded N/A guys...you want to keep a hot spark. NGKTR55/AL104's for your 3.4" Setup, TR6's are a tad cooler...best used around the 3.25" pulley area, and AL103's...are for the extreme supercharged application...3.0" pulley or lower. Here is a picture to reference the firing order and the correct coil number if yours aren't numbered or you just need a quick reference picture: http://i33.photobucket.com/albums/d6.../plugwires.jpg
    AC Delco Factory Replacements: Stock
    Autolite 606: Stock
    Autolite 605: 1 Heat Range Cooler
    NGK TR55: 1 Heat Range Cooler
    Autolite 104: 2 Heat Ranges Cooler
    NGK TR6: 2 Heat Ranges Cooler
    Autolite 103: 3 Heat Ranges Cooler
  7. #7 Re: platnium spitfire spark plugs
    I live here. TLSheff's Avatar
    Iridiums or Copper cores. Stay away from E3's and any platinum plug. Most boosted cars eat platinum plugs, stick with the ALs or NGK/ACDelcos.
  8. #8 Re: platnium spitfire spark plugs
    Jan 2013
    west palm
    these plugs have been on for quite some time, and there still going good but i will probably switch when i need new ones
  9. #9 Re: platnium spitfire spark plugs
    SE Level Member sco77's Avatar
    MD
    Platinum plugs were made for extended plug life, it's less conductive than copper and generally are hotter plugs, don't be fooled by marketing. Best to stick to copper and not be as lazy with car maintenance.... If you really want a longer lasting plug then iridium might be ok to use.
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  10. #10 Re: platnium spitfire spark plugs
    Over time the waste spark ignition system will eat the plugs and give you issues.
    Like said run some coppers on a modded car. I'd go with 605's on a simple 3.4 setup.
  11. #11 Re: platnium spitfire spark plugs
    St. Louis
    Quote Originally Posted by sco77 View Post
    In other ignition systems, yes. But for the GM waste-spark systems Platinums are a no-no as they WILL get eaten up rather quickly and cause misfires, often seen as soon as 6K miles on new plugs. Misfires under boost are an issue as they can lead to chipped pistons and then a new motor. These cars come with Irridiums from the factory, and coppers will work best on the 3.4 setup but require them to be changed more often but as usual you gotta pay to play.
  12. #12 Re: platnium spitfire spark plugs
    Jan 2009
    Tallahassee, FL
    Pay to play? They're like $12 for a set.
    77 Morris Garage B
  13. #13 Re: platnium spitfire spark plugs
    Quote Originally Posted by Sandman View Post
    Thats alot.
  14. #14 Re: platnium spitfire spark plugs
    Mullet Member Wotgtp's Avatar
    Connecticut
    I have to work time and a half at chic-fil-a to afford new plugs?
    Nope. Selling the car.
  1. spark plugs
    By samuelcb409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 01:32 PM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  3. Spark plugs, etc.
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-14-2010, 06:52 PM
  4. spark plugs?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2009, 11:37 PM
  5. spark plugs
    By NEONNIGHT34609 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-07-2008, 09:43 PM
