Thread: Oil leak from lower timing cover bolt hole
Results 1 to 5 of 5
  1. #1 Oil leak from lower timing cover bolt hole
    Aug 2013
    Kitimat, B.C.
    I finally found the source of my leak after changing the oil pan and oil filter adapter gasket. It's leaking from the lower bolt hole next to the oil filter adapter. I tried a few tomes last night with silicone and it still leaks. So I put an O ring as well as silicone in there to see what that does. But in the mean time while it's drying, what do y'all do?
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: Oil leak from lower timing cover bolt hole
    I put thread sealant on those type of bolts. Never had then leak.
    04 Comp G.
  3. #3 Re: Oil leak from lower timing cover bolt hole
    Aug 2013
    Kitimat, B.C.
    I did that a first and it leaked. So I figured it was on the outer side of the threads along the shaft of the bolt, so I silicones the whole shaft and that still leaked. So hopefully the silicone on the shaft with the o ring under the head will stop it.
  4. #4 Re: Oil leak from lower timing cover bolt hole
    Aug 2013
    Kitimat, B.C.
    Ahhhh, that didn't work. I let it set up overnight and when I got to work this morning it was still leaking. I took a good look and I don't see the timing cover cracked at all. I put lots of thread sealant on the threads and i siliconed the whole shaft liberally. what about oil residue in tye hole and on the bolt causing it not to seal? I am running synthetic oil. I can see it coming out the end of the hole underneith the bolt head. What about putting a copper washer there like on a brake calliper?
  5. #5 Re: Oil leak from lower timing cover bolt hole
    Aug 2013
    Kitimat, B.C.
    I will know in the morning when I get to work but so far it's not leaking. It was the bolt right above the bottom cover bolt, the one with the little stib sticking out. I remember taking that bolt out when I was running my belts as it was in the way since I don't have power steering and the belt runs directly up to the alternator, it was in the way.
  1. Lower control arm mount hole size
    By stingray355 in forum General Tech Discussion
    Last Post: 06-20-2013, 10:08 AM
  2. getting bolt with no head out of rear header join hole?
    By thomasd2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-26-2013, 08:57 PM
  3. lower insulator bolt help please
    By DarkPassNger in forum Brakes/Suspension/Chassis
    Last Post: 07-17-2011, 04:35 PM
  4. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
