So, I will be doing the LIM job as well, just wanted to get some feedback from the pro's about if I've got all the stuff I'll need/want while I'm in my Car's Engine-guts. I'll also be doing a pass. side (right hand?) axle and hub replacement, previous owner must have hit a curb...or pedestrian...or rock.
In case its not in my sig or info somewhere: 2002 GTP, 62k miles
Here goes, from RockAuto.com:
Manufacturer................Name.................. .........................part #
Value Pro ...................Driven Hub w/ Integral ABS..............513179
Cardone Select ............Front Right CVA ............................661256
Fel-Pro........................Intake Manifold Gasket....................MS98014T
Fel-Pro .......................Valve cover Gasket w/ Grommets......VS50465R
Fel-Pro........................Plenum Gasket...............................MS95744
Fel-Pro........................Throttle Body Gasket......................61024
Fel-Pro........................T-stat housing gasket...................35666
Fel-Pro........................Fuel Injector O-Ring........................ES70599 (x2 packs = 8 all together...just in case?)
Dorman.......................Coolant Elbow (aluminum)..................47065HP
Autolite.......................Spark Plug.....................................606
Bosch..........................Spark Plug Wire Set........................09457
From the hardware store:
Thread Sealant
At some point I'll be making my own Air Intake, most likely with a Spectre filter and a home-made box (lets not worry about the differing opinions about open vs CAI though)
Before I place orders, is there any other maintenance or preventive items I should be looking at? This is a daily driver for now, no need to go racing or up HP or anything, just want as good of MPG as I can get and make it last as long as possible. I'm putting roughly 150 miles/day plus or minus.
