This is a 2002 3800sc in a fiero. I just fired it up for the first time and it won't stay running unless I press the gas. If I taKe the line off the fuel pressure regulator it will start and stay running, I'm not sure if I have my lines propper though. I have gotten rid of the boost bypass. How I have it now is I have one line going from the throttle body to the purge solenoid on the fender and to the line from the fuel tank. Then another seperate line starting at the octopus thing to the fuel pressure regulator. Then another seperate line from the map on firewall to the port under the supercharger. Should I tie in the line from the octopus thingy to the fuel pressure regulator to the map and end at the port under the supercharger?
