Thread: Won't stay running unless I press the gas
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by Ginseng View Post
    try resetting your pcm by unplugging the battery possibly
    K I just did that for about a half an hour and no luck, still stalling.
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #22 Re: Won't stay running unless I press the gas
    gardner,mass
    you sure you have no vac leak?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #23 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    Not sure, can't get it running long enough to check by myself.
  4. #24 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    Turns out the iac was dirty,I cleaned it and not it's drivable but it's stumbling a bit.
  5. #25 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    Its stumbling a bit so i did a DTC scan and I got these for codes:
    P0303 - Cylinder 3 Misfire Detected
    [] P0452 - Fuel Tank Pressure Sensor Circuit Low Voltage (SES) (Pending) (Old) (History) (Current) (Immature)
    [] P0481 - Cooling Fan Relay 2 Control Circuit (SES) (Pending) (History) (Current) (Immature)
    [] P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency (Immature)
    [] P0243 - Turbocharger Wastegate Solenoid 1 (History) (Immature)
    [] P0300 - Engine Misfire Detected (SES) (Pending) (History) (Current) (Immature)
    [] P0463 - Fuel Level Sensor Circuit High Voltage (Pending) (History) (Current) (Immature)
    [] P0656 - Fuel Level Output Circuit Malfunction (Pending) (History) (Immature)
    I just deleted the p0243 code and will have to look for the source of the cylinder #3 missfire but what about the rest? Should I delete them codes as well? other than the maf, I just sprayed some carb cleaner so I will take it back out and re clean to see what it does for that code.
  6. #26 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    I went out and verified a spark at te number three coil. And I also verified there's power to both wire at the injector and are pulsing when running. So I pulled the plug and man would I looooove to put a steel toe boot to the balls of the f'er who came up with that design. Well the plug was blacker than tobeys a$$, not sure if that's because of the short firing time when I checked for spark and then again for about 30 secs checking the injector. Just thinking as I'm typing this I guess I should check for spark by grounding the plug attached to the wire incase there's something wrong with the wire. Any idears?
  7. #27 Re: Won't stay running unless I press the gas
    Feb 2009
    flintnasty MI
    if a motor was sitting and not running for awhile they like to stick closed... I usually idle the motor and smash the injectors with a screwdriver. you could rig up a little test rig and power the injectors with a battery a bunch while beating on them.
  8. #28 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    I removed the #3 spark plug an'd I guess I'll never know if that was the problem as I dropped thesum*****. I was trying to put the new one in and was having a problem getting it in when I noticed the oil dipstick tube was aff to the side but in the way. So I had to pull that out and got the plug and metal heat shield back in. I put an ear plug in the oil tube hole for the time being and fired it up and clears the codes that haven't come back. I was just thinking, is it possible that the metal dipstick tube that was obviously up against the metal heat shield causing the missfire?
  9. #29 Re: Won't stay running unless I press the gas
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    not sure what the problem is but for a minute there it sounded like a fuel issue. Sitting for a while could cause the car some laziness and or stale fluids like the FUEL. Try a new fuel filter and some fuel injector cleaner/stabilizer. May help, may not but im sure your fuel system wouldn't mind it. I use chevron Techron but lately I've been using Royal Purple Max fuel clean in my cars and others. here it is[IMG][/IMG]
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  10. #30 Re: Won't stay running unless I press the gas
    Aug 2013
    Kitimat, B.C.
    It might have been the spark plug or it was grounding out. Whatever it was its gone now. The fuel was completely drained when I put the new fuel pump in. I also put in new fuel filter also. I will put in injector cleaner just an added insurance.
  11. #31 Re: Won't stay running unless I press the gas
    Jul 2012
    North Philly
    So its running now...GREAT. Keep up the maintenance on these 3800s and they'll last forever.
  1. l67 engine wont stay running..got the car running. tons of white smoke from exhast
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 05:14 PM
  2. car won't stay running
    By nawarkk in forum General Tech Discussion
    Last Post: 12-18-2012, 11:21 AM
  3. Car won't stay running...
    By 2000GTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-26-2010, 06:43 PM
  4. wont stay running
    By DarkCherry in forum General Tech Discussion
    Last Post: 09-24-2010, 11:06 PM
  5. Car will not stay running
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 07:30 AM
