I have been experiencing some idle issues with my GTP and I was wondering if the GTP community could help me out. The issue has been on and off for about a month now, sometimes it will act up a couple times a day or it could act up once a week. It only does it at idle, doesn't matter if the car is cold or at operating temp.
When the car is first started in the morning it will idle for a couple of minutes then the car will start to cycle the idle from 300-800 rpms. It will continue to do this for about a minute and then the car will die. The car will restart back up with no problems. When the car begins to cycle the rpms if you apply a little gas and bring the rpms up to 2000 the car will clear up but as soon as you ease off the gas it will start to cycle the rpms again. You can do this a couple of times and then it will eventually idle clean.
It will also act up at operating temp too. Pulling up to a stop sign the car will start to cycle the rpms like it does when it is cold. You have to keep one foot and the brake and one on the gas to keep it running. But going down the road or at WOT the car is fine.
Any help will be greatly appreciated.
Jared
