Thread: 06 GT (L32) -codes P0033 P0103 P0443
Results 1 to 4 of 4
  1. #1 06 GT (L32) -codes P0033 P0103 P0443
    Jun 2012
    Cold Spring, MN
    Ok, so I just had a buddies shop change some parts over this past weekend while I was out of town:
    coolant elbows
    water pump
    valve cover gaskets
    Before I brought it in those were the only issues mechanically aside from an occasional EGR code (twice in the past 2 months).
    I know what the codes are:
    P0033 Supercharger boost bypass valve circuit error
    P0103 MAF
    P0443
    EVAP Purge Solenoid Valve 1 Control CKT
    What could happened that would cause these all to occur just by changing the parts I mentioned above?
    Just seems wierd considering they only drove into the shop and backed it right out (no odometer change).
  2. #2 Re: 06 GT (L32) -codes P0033 P0103 P0443
    I'd make sure everything is plugged in.
  3. #3 Re: 06 GT (L32) -codes P0033 P0103 P0443
    Jun 2012
    Cold Spring, MN
    I forgot to say, aside from the CE light I also noticed the shifts were fairly violent and a simple touch of the throttle feels like the engine wants to climb out of the engine bay (a lot of jerking around, kind of like vacuum issues).
    I did a look over in the dark, unplugging the BCS and MAF and plugged them back in to make sure they were connected, checked for vacuum leaks (disconnected vacuum lines) but all the lines are connected securely.
  4. #4 Re: 06 GT (L32) -codes P0033 P0103 P0443
    Jun 2012
    Cold Spring, MN
    Found the issue -fuse #12 was only in half way.... Must have come loose when the fuse box was moved to allow easier access to the alt bracket and water pump.
  1. P0171, P0440, P0443 codes
    By stevenj in forum Engine
    Last Post: 10-29-2012, 09:29 AM
  2. P0172/p0103 error code
    By 2003grandprixgtp in forum General Tech Discussion
    Last Post: 03-27-2011, 07:45 AM
  3. odb p0103 and p1441
    By tc300 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-21-2011, 11:08 AM
  4. p0443 and p0102
    By Lawngoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2010, 03:21 PM
  5. Dtc p0103
    By fst in forum PCM Tuning
    Last Post: 10-05-2008, 02:33 PM
