Thread: L32 Flywheel Help!?
Results 1 to 3 of 3
  1. #1 L32 Flywheel Help!?
    Jan 2013
    Anderson SC
    Hey guys I just got my custom torque converter in and it does not fit. The bolt hole pattern on the converter is 9 1/2" the bolt pattern on my 05 grand prix L32 flywheel is 8 3/8". the problem I am having is all the torque converter catalogs have the SC3.8 having a 9 1/2 to 9 3/4 no where do I see less than a 9" bolt pattern. Does anyone have a L32 flywheel laying around to measure bolt hole to bolt hole? Is mine different for some reason? I am running this engine in a off road race truck with a 700R4 in it, hence the reason I needed a custom converter.
  2. #2 Re: L32 Flywheel Help!?
    Jan 2013
    Anderson SC
    Well just some good info the bolt pattern on a SC3.8 flywheel is 9 3/4" bolt circle and a .824" pilot. You measure fron the center of torque converter to bolt hole then multiply by 2 and that is how you find your bolt pattern.
  3. #3 Re: L32 Flywheel Help!?
    An L32 has a dual drilled flex. The two patterns are 245mm and 258mm. Sorry, can't translate them at the moment.
  1. flywheel
    By Eric Whitter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2013, 06:45 PM
  2. 5-speed flywheel
    By l67ss in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 01-29-2013, 09:41 PM
  3. Help!!! Flywheel won't turn!
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2011, 11:44 PM
  4. Flywheel position
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 09:34 AM
  5. is the flexplate the same thing as the flywheel?
    By 98bdgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2009, 12:50 PM
