Yes I understand its been discussed literally a 100 times probably,I want a 100% answer,I'm getting a Montana and I want to put the l67 in it,if the 3.8 sc bolts right in the grand prixs it should the Montana right?,I know I need the PCM and harness,what else do I need,can I keep the fuel pump that was with the 3.4 or do I need the 2 speed if so how will it wire up,I want to do it,I'd like a 2000 or up since it has that updated speedo,can I get a exact answer what I need and what to do,I know it works it's been done,thanks
