Thread: Engine rattle at 2100 RPM
Results 1 to 10 of 10
  1. #1 Engine rattle at 2100 RPM
    Feb 2008
    I've noticed since I put my engine back together that it gets a rattle at about 2100 RPM and will continue to rattle up through the RPM range and back down to about 2000. I've disconnected both belts and fired it up with the same result, so I'm 99% certain it's not a pulley/pump or my blower ( I held it from moving while testing). It seems to be coming from the front bank more than the back. It's the kind of noise that a shot bearing makes when you spin it quickly. It's quiet at low RPM, but hits instantly at a certain speed. I'll try to get an audio clip of it if I can get it to pick up the noise I want.
  2. #2 Re: Engine rattle at 2100 RPM
    Jul 2008
    Poteau Oklahoma
    rocker arms?
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  3. #3 Re: Engine rattle at 2100 RPM
    Feb 2008
    I checked the front bank, and all are snug. I don't look forward to checking the rear bank if that's what needs to be done next.
  4. #4 Re: Engine rattle at 2100 RPM
    TDCRacing
    Guest
    ummm...lifter tap?
  5. #5 Re: Engine rattle at 2100 RPM
    Feb 2008
    God, I hope not! I replaced the darn things when I redid the engine. If it's lifter tap, they're all tapping, because it's more of a whirr than a tapping.
  6. #6 Re: Engine rattle at 2100 RPM
    GT Level Member TurboKent's Avatar
    Woodward, OK
    if it was a honda i would tell you that the hamster on the wheel is probably out of breath and needs some water.
    2003 Grand Prix turbo intercooled
  7. #7 Re: Engine rattle at 2100 RPM
    Feb 2008
    Quote Originally Posted by TurboKent View Post
    LAWLZ!
    Well, now that I have my squeaky belt taken care of, I may try to get a decent recording of it. I've been to the strip twice (a total of ~20 passes) and run it hard a lot on the street since the rebuild, so I don't think it's detrimental...
  8. #8 Re: Engine rattle at 2100 RPM
    Jul 2008
    Germantown, Maryland
    you say that now......
  9. #9 Re: Engine rattle at 2100 RPM
    TDCRacing
    Guest
    Well I wonder what it could be then.....Lets hear that recording.
  10. #10 Re: Engine rattle at 2100 RPM
    Feb 2008
    Alright, I got a few recordings for you all to listen to. The specific noise is difficult to hear, but is audible. Any squeaking you hear is my alt bearing, so ignore that particular noise.
    http://s281.photobucket.com/albums/k...t=PICT0348.flv
    http://s281.photobucket.com/albums/k...t=MVI_2991.flv
  1. Help with 2007 Dash Rattle
    By leeklm in forum 04+ Specifics
    Last Post: 01-29-2011, 12:18 AM
  2. Supercharger noise, rattle HELP!
    By Mvfootball1 in forum General Tech Discussion
    Last Post: 08-26-2010, 04:49 PM
  3. Anti Rattle Clips
    By My '08 GXP in forum Brakes/Suspension/Chassis
    Last Post: 11-19-2008, 08:42 PM
  4. Rattle Trap....
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2008, 07:11 PM
  5. Valves rattle
    By johndaysGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 05:46 PM
