Thread: Anyone have a saftty precaution for your I/C pump failing
Results 1 to 9 of 9
  1. #1 Anyone have a saftty precaution for your I/C pump failing
    Slower, Lower Delaware
    Is there a way to know if your I/C pump has stopped. I'm running a 3.4 pulley and don't think my engine would last long if my I/C pump stopped.
  2. #2 Re: Anyone have a saftty precaution for your I/C pump failing
    You can build yourself a flow detect kit.
    http://www.grandprixforums.net/how-b...tem-39799.html
  3. #3 Re: Anyone have a saftty precaution for your I/C pump failing
    Thanks
  4. #4 Re: Anyone have a saftty precaution for your I/C pump failing
    Np.. that work for you or would you like more suggestions?
  5. #5 Re: Anyone have a saftty precaution for your I/C pump failing
    That looks like it will do it. I have a aeroforce that I use but it's not permanently mounted.
  6. #6 Re: Anyone have a saftty precaution for your I/C pump failing
    Cool...cause I didn't have anything else. Who knows what I might have made up.
  7. #7 Re: Anyone have a saftty precaution for your I/C pump failing
    Florida
    If you don't already have one a aero force to scan kr.
  8. #8 Re: Anyone have a saftty precaution for your I/C pump failing
    Max Cook
    Guest
    Mine died once. I just didnt got WOT till it was fixed. If I turn my car to accessory only I can hear it running so its easy to know if it died. As long as you watch your KR everytime you go WOT (I always do regardless), you'll be able to let off likely before anything bad happens.
  9. #9 Re: Anyone have a saftty precaution for your I/C pump failing
    Yeah, I need to get my gauges mounted.
    Quote Originally Posted by Max Cook View Post
  1. Laugh with me at my failing BCM + questions
    By acidcrashdburnd in forum General Grand Prix Discussion
    Last Post: 06-26-2013, 11:20 AM
  2. Smog pump failing
    By v8teezr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-13-2011, 12:11 AM
  3. Trans failing?
    By AzrakMCSS in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-01-2011, 06:24 AM
  4. Strut mount keeps failing
    By Silver GTP in forum Brakes/Suspension/Chassis
    Last Post: 12-13-2010, 12:37 AM
