Thread: Rocker Arm Bolts
Results 1 to 4 of 4
  1. #1 Rocker Arm Bolts
    Jul 2013
    Oakland, Ca.
    Guys,
    I'm getting ready to to button things down, in terms of the valve train. I have been reading through the forum that the rocker arm bolts are TTY, so I am getting ready to order reusable ones, but need to confirm the part number first. I have a 1997 Prix GTP with stock valvetrain. The rocker arm bolts are Comp Cams part# 1053B-16 (I'm ordering the "16's" because these are the ones Summit has in stock, and ready to ship), are these the correct bolts for a 1997 GTP?
    http://www.summitracing.com/parts/cca-1053b-16
    Thanks in advance!
  2. #2 Re: Rocker Arm Bolts
    GTP Level Member tms8582's Avatar
    Washington Michigan
    you torque them down to 25 pounds. I have a set of reusable ones for your motor that I will sell you. I used them for only a couple of months and then switched to yellaterra rockers which came with their own bolts. These are the ones I have http://intense-racing.com/Merchant2/..._Code=3800_HCV
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  3. #3 Re: Rocker Arm Bolts
    Jul 2013
    Oakland, Ca.
    Quote Originally Posted by tms8582 View Post
    you torque them down to 25 pounds. I have a set of reusable ones for your motor that I will sell you. I used them for only a couple of months and then switched to yellaterra rockers which came with their own bolts. These are the ones I have INTENSE Racing: INTENSE Re-usable Rocker Arm Bolts
    I appreciate the offer tms8582, but the reason I'm going with Summit Racing is because I get them next day, and I really need to get this thing up and running ASAP. Can anybody please confirm the Comp Cams being the ones I need. I need to place the order today. Thank you.
  4. #4 Re: Rocker Arm Bolts
    Jul 2013
    Oakland, Ca.
    Got the bolts in this morning, and now the only thing left is to install the blower.
  1. '01 3.1L Serpentine belt and rocker arm bolts
    By Matt Beauchamp in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-23-2012, 07:28 AM
  2. rocker bolts
    By kevins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2011, 08:43 PM
  3. Rocker Arm Bolts
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2010, 10:01 PM
  4. best rocker bolts
    By 2000gtp1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2009, 11:18 AM
  5. Rocker bolts
    By Kerker48 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-16-2009, 02:29 PM
