Thread: Plastic Vacuum Line Replacement?
Results 1 to 13 of 13
  1. #1 Plastic Vacuum Line Replacement?
    SE Level Member 98RedGTP's Avatar
    Feb 2013
    Hazelwood, MO
    My 98 GTP has all this old brittle plastic vacuum line from the bypass valve to the MAP, is it safe to replace it all with rubber line and new Ts as needed?
  2. #2 Re: Plastic Vacuum Line Replacement?
    Grand Rapids, MI
    Absolutely. And if you ever want to have original stuff again, GM sells a vacuum kit that includes all lines and fittings.
  3. #3 Re: Plastic Vacuum Line Replacement?
    Feb 2013
    Hazelwood, MO
    Awesome. The T at the LIM broke and I know what aged plastic line does, break. Not much else.
  4. #4 Re: Plastic Vacuum Line Replacement?
    Grand Rapids, MI
    Yeah mine broke long ago. I now have a plastic T with rubber lines in its place.
  5. #5 Re: Plastic Vacuum Line Replacement?
    Jul 2013
    san diego
    i re-did all my vacuum lines with rubber, fits good and snug.
  6. #6 Re: Plastic Vacuum Line Replacement?
    SE Level Member Thethudelh's Avatar
    Apr 2014
    Sandy Ridge,NC
    Does anyone have the part number for that kit or some other alternative with parts from advance or auto zone? Just replaced my lim and broke some vacuum ts. Firgured i go ahead and replace lines as well.Thanks.
  7. #7 Re: Plastic Vacuum Line Replacement?
    Donating Users Uno99's Avatar
    Appleton, Wi
    Don't have the part number but I can tell you its around $70 from the dealer. Have you checked rock auto?
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  8. #8 Re: Plastic Vacuum Line Replacement?
    GT Level Member dezebe1's Avatar
    May 2013
    Dallas TX
    Quote Originally Posted by Uno99 View Post
    How you figure $70 from the dealer, I just bought one today and it's $16 for a brand new one, I'll sell it to you for $30. Part #24508742
    Team JB-Weld
  9. #9 Re: Plastic Vacuum Line Replacement?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by dezebe1 View Post
    When mine broke this winter, it was $38 from the dealer. You two are literally on opposite ends of the country, prices will vary.
    7"
  10. #10 Re: Plastic Vacuum Line Replacement?
    Appleton, Wi
    Ok your right......I'm wrong......i must have replace a different vac line but i can't tell you the one i bought from the dealer was $70. Relax.
  11. #11 Re: Plastic Vacuum Line Replacement?
    Paid $12 for the replacement one I picked up from the dealer.. Someone got raped.
    04 Comp G.
  12. #12 Re: Plastic Vacuum Line Replacement?
    Oct 2011
    Toledo, OH
    Fortunately I declined, and paid $1 for the rubber line at O'Reilly
    7"
  13. #13 Re: Plastic Vacuum Line Replacement?
    Grand Rapids, MI
    honestly. go buy a couple vacuum Ts at the auto parts. buy a crap ton of hose. and you can create even better vac lines than gm gave you
  1. Broken plastic hose, vacuum leak, help needed!
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2011, 11:45 AM
  2. Vacuum line replacement
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2011, 12:08 PM
  3. Plastic fuel line repair?
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2011, 08:50 PM
  4. Need to replace plastic line and having an issue.
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2009, 04:39 AM
  5. Need to replace plastic line and having an issue.
    Last Post: 02-15-2009, 11:39 PM
