Thread: 3.5 pulley on stock manifolds
Results 1 to 20 of 22
  1. #1 3.5 pulley on stock manifolds
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    Hi just wondering if anyone has run a 3.5 pulley on a gtp with stock manifolds and ubend delete cone filter and 104s stock tune with no knock my dad wants more piwer in his gp and i have 3.5 i dont use
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: 3.5 pulley on stock manifolds
    people have done it.
    Just scan, then you'll know for sure.
  3. #3 Re: 3.5 pulley on stock manifolds
    antioch ill
    this will happen
  4. #4 Re: 3.5 pulley on stock manifolds
    Thanks matt i have a ls1m somewhere. But its weird my gtp had knock and i had ssic and headers but that was because of an exhaust leak and vac leak
    sold 97 GTP stock
  5. #5 Re: 3.5 pulley on stock manifolds
    Maybe ill just get a plog for his car
    sold 97 GTP stock
  6. #6 Re: 3.5 pulley on stock manifolds
    Nov 2011
    NY
    Plog is just half a header... Why not go all the way? Lol... SD's are cheap enough, just my $.02
  7. #7 Re: 3.5 pulley on stock manifolds
    May 2008
    Schuyler, NE
    SD's are a pain.
    It will be fine with stock manifolds and a 3.5.
  8. #8 Re: 3.5 pulley on stock manifolds
    Quote Originally Posted by nascartech View Post
    Yeah, it knocked because it was broke.
    SD's are a pain.
    My car needed a 3" DP and other small crap to get away with a 3.5".
  9. #9 Re: 3.5 pulley on stock manifolds
    May 2008
    Schuyler, NE
    Quote Originally Posted by blueguy View Post
    I can believe that. I used to run a 3.4 with 3"DP + supporting mods on my 97 back in the day. It usually didn't knock.
  10. #10 Re: 3.5 pulley on stock manifolds
    Mine went knock free after doing springs/1.84's.
    I had like 2* at the shift before that.
    Also did PEM's and 180*/plugs/wires/filters/mounts at that time too.
    So, could have just been crappy tune-up stuff too.
  11. #11 Re: 3.5 pulley on stock manifolds
    Ya getting ssic to seal is a pain and my sd headers were leakibg so when my car goes back together with the new cam and complete rebuild from heads up i am gunna use some copper rtv hope that helps
    sold 97 GTP stock
  12. #12 Re: 3.5 pulley on stock manifolds
    SSIC's suck because the cores warp easy.
    Get a full size IC or nothing.
    As for headers, I think I've done...six sets of SD's? Only one car had issues...and that was the blown out crappy Chinese flex.
    Which, just delete that crap if you've got solid mounts.
  13. #13 Re: 3.5 pulley on stock manifolds
    Ya im gunna run 3.2 no ic for now then 2.8 when i get ic
    sold 97 GTP stock
  14. #14 Re: 3.5 pulley on stock manifolds
    You can't just guess on pulley size.
    Just because you'll have valvetrain work, doesn't mean you can run a small pulley. The pulley size is dictated on how well the car flows and how good the tuner is.
    You could run a 2.5" pulley on a stock car with no timing and a 10:1 AFR. Doesn't mean it'll be fast or reliable.
  15. #15 Re: 3.5 pulley on stock manifolds
    if i were doing it again, i'd skip headers and just run a 3" downpipe.
  16. #16 Re: 3.5 pulley on stock manifolds
    Cam ported heads headers double roller 130 springs ls7 lifters etc and u can,t run a 3.2
    sold 97 GTP stock
  17. #17 Re: 3.5 pulley on stock manifolds
    And im getting it tuned by intense since my cam is a stage 3 intense cam so i figured they would know how to tune that cam well oh and 60lb injectors
    sold 97 GTP stock
  18. #18 Re: 3.5 pulley on stock manifolds
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    Sounds just like my set up. I don't see much KR at the 1-2 shift. But occasionally 3-5* at the 2-3 shift. I just need an actual tune.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  19. #19 Re: 3.5 pulley on stock manifolds
    That's what I'm saying...
    Just because someone can run it...doesn't mean you can.
    And just because you've got "X" mods doesn't mean you can run "Y" pulley...
    It'd be faster on a 3.4" if you were knocking on a 3.2" anyways.
    Pulley envy is the death of all these cars.
  20. #20 Re: 3.5 pulley on stock manifolds
    Mullet Member Wotgtp's Avatar
    Connecticut
    I'm waiting for the E85 and NIC guys to come in here and rustle jimmies.
  1. Question about stock exhaust manifolds.
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-01-2011, 07:31 AM
