Thread: car starts to misfire when gets hot? help!!!!
Results 1 to 13 of 13
  1. #1 car starts to misfire when gets hot? help!!!!
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    My car starts to run very poorly and misfires on every cylinder randomly about 3 at a time, it usually happens after about 10 minutes of driving. i have replaced the coils awhile ago, i had zzp wires and just changed those to autolite professional series wires. and i have autolite 605's, aslo i just replaced the icm. i have an aeroforce that tells me the misfires and when its running good it still shows a couple of misfires but i think that is due to the vs cam with no tune, but when it runs like crap it shows anywhere from 45-60. it seems that cylinders 3,4,6 has the most misfires.
    I think it has something to due wiht the coolant temperature sensor, but i could be wrong. not sure.
    Has anyone had any similar problems or can tell me whats wrong?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: car starts to misfire when gets hot? help!!!!
    Nov 2011
    NY
    Quote Originally Posted by Doug 97 gtp View Post
    really...?
  3. #3 Re: car starts to misfire when gets hot? help!!!!
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    If you have an aftermarket cam, you have to set -Engine Misfire- to "No Report" in the pcm. Hope you have tuning software, or know someone who does.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  4. #4 Re: car starts to misfire when gets hot? help!!!!
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Oh my.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  5. #5 Re: car starts to misfire when gets hot? help!!!!
    Sep 2011
    palm harbor florida
    ive got 700 miles on the new motor and its just now starting to do it!?!?! what the cam decided to play games with me now. i had no problem before
  6. #6 Re: car starts to misfire when gets hot? help!!!!
    Sep 2011
    palm harbor florida
    the only tuner that i know of is in daytona... how the hell am i going to get my car there
  7. #7 Re: car starts to misfire when gets hot? help!!!!
    Florida
    The last vs cam I tuned did not set the misfire code until we loaded one of the last files. We were starting to think we didn't need to remove it.
  8. #8 Re: car starts to misfire when gets hot? help!!!!
    Sep 2011
    palm harbor florida
    i did a little more testing and it seems that i have a bad coil. because the car only misfires when it gets warmed up and its not the plugs wires or the icm. after testing the coils i want to say that thats the problem.
  9. #9 Re: car starts to misfire when gets hot? help!!!!
    Oct 2012
    New Jersey
    Hopefully it's just a coil since it seams really hard for you to get your pcm tuned.
    Good luck and keep us updated.
  10. #10 Re: car starts to misfire when gets hot? help!!!!
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Hope you don't have the metal heat shields on the plugs. If so take them off.
    If You Cant Hear The Whine You're Too Far Behind...
  11. #11 Re: car starts to misfire when gets hot? help!!!!
    Sep 2011
    palm harbor florida
    i dont. i got some new coild today and will be putting them on tomorrow hopefully my misfires will go away
  12. #12 Re: car starts to misfire when gets hot? help!!!!
    If your engine temp sensor is old it wont hurt to replace it, I have heard of faulty temps sensors causing misfires.
  13. #13 Re: car starts to misfire when gets hot? help!!!!
    Sep 2011
    palm harbor florida
    well i replaced my coils and the car still does it. now i have moved to think that it may be my map sensor because the misfires come and go
  1. 98 GTP starts and dies intermittently on cold starts
    By toadson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2013, 07:53 PM
  2. Starts, runs fine for a week, then won't start for 5 minutes, then starts and runs...
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 05:33 PM
  3. 2001 Grand Prix GT starts then stalls then starts up and is fine???
    By 81X11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-06-2012, 10:29 PM
  4. starts without key
    By stlunatics2oo3 in forum General Tech Discussion
    Last Post: 10-23-2010, 04:16 AM
  5. GTP with misfire at higher rpms or when boost starts to kick in
    By 00obgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2009, 05:27 PM
